Question about Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case
I have a Nuvi 250 9 months old will not power up
I have a Nuvi 250 just 9 months old will not start,screen blank, with car charger or usb connected, still not powering up.
  • Garmin Expert
  • 343 Answers
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
I have a Nuvi 250 9 months old will not power up - clip_image001.jpg clip_image002.jpgIf the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
Posted on Jan 17, 2010
SOURCE:
My Garmin Nuvi 250 w gets stuck on the screen showing a picture connecting a computer to Garmin. I have it in my car and resetting hasn't worked. any suggestions
The nuvi is being put into mass storage mode (the mode used to transfer data back and forth to a computer). This is usually caused by using the wrong vehicle power cable.
The correct cable is Garmin part number 010-10723-06.
http://www.gpscity.com/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi.html
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
How do i charge my garmin by attaching via a usb cable to my mac
When you connect the satnav to a computer with a usb cable it automatically starts to charge. However it takes about 8 hours to charge compared to around 4 on a car charger.
Oct 11, 2010 | Garmin nuvi 250 GPS Receiver
My Garmin nuvi 250W GPS is NOT powering on.
try connecting it to your computer via the usb cable. that may reset it. outdated maps will not cause this problem.
Feb 21, 2010 | Garmin nuvi 250W GPS Receiver
My garmin nuvi, which I purchased less than two months ago, no longer loads. It appears to start up with the introductory screen then goes blank. The charger is hooked up and is apparently working.
the battery is either to low or shot,
plug it in to either the home charger, car charger or usb for a few hours and try it again. once it starts, go in the gps main menu and see what the battery meter tells you (what does it look like, is the meter moving ect)
Jan 23, 2010 | GPS
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 250 will not turn on when charging.
There are two types of leads that you can buy.
The one supplied with the Garmin expects you to plug the GPS into the PC via the USB and if you use this to try and charge your Garmin in your car it will think it is connected to the PC and show the connection screen. it will charge the unit but you can't see the map.!!!
Make sure that you buy a lead specially for the Garmin for use in the car its the only type of SAT NAV that you will have this problem with.
LOL
Sep 12, 2009 | Garmin nuvi 250W GPS Receiver
Nuvi 250- goes to blank screen when u hit SPELL
Sounds like corrupted firmware. Go to www.garmin.com and download their webupdater. Run it and connect a USB cable between your Nuvi and the PC. Let the webupdater look to see if there are any firmware updates. If so, install them. If not, let it reflash your current version.
- Jim
Nov 27, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 250
RESET THE GARMIN NUVI Start with the unit off ,: press and hold the corner ( cant remember what corner top/bottom//left//right) tye each one: one at a time while olding the screen down on one of the corners press the power switch to the on position your unit should flash a few times then you sould see the logo apear GARMIN ( I would tell you witch button for sure it was but can;t bring myself to reset everything on my unit at this time)(sry :))
Sep 11, 2008 | Garmin nuvi 250 GPS Receiver
Nuvi 250
Have you used the wall charger to fully charge the battery? If the battery is too low after lying around for a month it wil not start, giving it a couple of minutes of charging wo'nt help either, a good and full charge will!
Mar 29, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case  Logo
281 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
