Question about Saeco Odea Giro Plus Coffee Maker
We have a Saeco Odea Giro coffe machine, and it seems as if the sprouts are blocked, it grinds and pumps the coffee, but nothing comes out of the sprouts. it doesn't seems there is a pressure problem, but it sounds as if the machine is over working itself (pumping towards the inside)
  • 55 Answers
Check the screens in he brew group to make sure they are clean and clear also under the top screen theres a small hole make sure that is clear also
Posted on Dec 18, 2009
  • Dino Dec 27, 2011
    I had the same issue and found that the boiler was blocked. Try the steam wand and if you find that the steam pressure is weak, it's a good indication that the boiler is clogged with calcium. Forget about descaling, it's to late for that. I tried it several times myself. I had to repace the boiler. (about $75.00) Take it to a service centre if you don't feel confident to DIY.
My Odea Giro stops working when entering the brew pump cycle. When I run it without coffee it runs fine. When I add coffee it stops after the grind cycle. I have replaced the microswitches and cleaned the...
I had a similar problem
Mine was caused by an "oily" type of coffee beans. Grind was accumulating in the grinder.
I did open the machine and cleaned the grinder physically. At least, try to remove all beans and sucked with a vacuum the interior of the grinder screw.
Good luck
Jun 18, 2014 | Saeco Odea Giro Plus Coffee Maker
How to open the saeco odea
After descaling and rinsing, you need to hold the hot water button for 6 seconds to reset the descaling indicator.
Mar 26, 2013 | Saeco Odea Giro Plus Coffee Maker
Coffee grinds but nothing comes out of dispensing head. Brew group wont come out.
I have the exact same problem and haven't found any replies to your request. Did you finally find a solution to the problem? Thanks
Dec 11, 2011 | Saeco Odea Giro Plus Coffee Maker
Hi, I've got a saeco odea giro plus. 3 weeks old, the descaling ight came on. I followed descaling steps in manual. rinsed off brew group and place it back in unit. now the system will prime, grind, I...
Look at the brewing group where the top strainer is. The small holes are blocked with coffee. The water can not pass through them.
You will need to unfold the two screws at the top and then remove the strainer, grow and clean it and clean it if the holes are blocked.
Do this only
Apr 29, 2017 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Saeco odea giro is not grinding enough coffee.. the pad is like half or less than that.. it seems like a pcv problem .. HOw can I reset or reprogram to grind more coffee?
Hi,..These saeco models have a auto adjusting grinder. If the brewunit is heavy or in other words overloading, the machine will reduce the grinding time lesser to produce less ground coffee.If it senses the brewunit is smooth and light in loading (compressing the grounds), it will increase the grinding until it reaches the optimum dose. So it is important to clean and lubricate the brew unit at all times. Hope it will solve the problem. Good luck.
Jun 18, 2010 | Saeco Odea-Giro Espresso Machine
My Saeco Odea Go always seemed very noisy?
maybe pump make noise,check holder of pump,or replace pump
Aug 29, 2009 | Saeco Odea Go
Saeco Odea Giro Plus Coffee Maker Logo
650 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
