Question about APW Wyott C*Radiant, Lighted Single Overhead Warmer - 18''L - Remote Toggle - Low Wat
Overhead light, controlled by a switch, will not turn off. Stays on.
    Guru:
  • 597 Answers
Obviously your switch is broken internally. You'll need to turn off the breaker to the light which will be evident when it goes off. Then change out the switch. Turn breaker back on to restore. I'm assuming that this light/switch worked once upon a time and that it was wired right.
Posted on Dec 11, 2009
The overhead light between the driver and passenger won't come on where do I find power for this light
Your instrument cluster light dimmer switch if turned to max, will click on the roof light..Some cars also have overhead light disable sw near light control panel. Also door sw around door where it closes
May 15, 2017 | Cars & Trucks
Overhead light turns on when walking into garage. sensors turn it on. how can we fix this?
Hi Laura:
Mine does this too. I just thought that it was supposed to do this as it made sense to me. The light automatically turns off after a few minutes, so if the sensor indicates that someone is walking in and out while the door is open, the light stays on.
I'm thinking........... It ain't broke..... don't fix it.
Jun 22, 2015 | liftmaster Chamberlain Garage Door Opener...
How do I turn off the machine safely?
Do people still use those?
OK. Dim the lamp, leave the fan on for about 10 minutes.
Turn off unit and LEAVE UNTIL COOL.
Feb 13, 2015 | Apollo Ai-1000 Overhead Projector...
Tps problem on a 2002 mercury sable
Then you did not fix the problem. Codes are not cut and dry, it can be the part the wiring to it or in rare cases a defective Powertrain control module (PCM)
Mar 28, 2014 | 2002 Mercury Sable
Glove box light won't turn off
Check around the area that the glove bx contact when you closed.
There is a tiny switch there (spring load kind push in and out).
-If you find it, push or press in by hands to see if it off or not.
-If off.>>> You need to adjust the glove bx door to push in when it in closed position.
-If it's not.>>> Replace the switch.
Mai Lor
Feb 24, 2013 | 1988 Dodge Dakota
I have three wires, two are black and one is white. I want to have the outlet active and the switch control an overhead light. How do I connect the wires?
Connect the white on the switch to the white in your house, one black to the hot coming in, and the other black to the hot wire to the overhead fixture.
Mar 13, 2011 | Leviton Decora Combination Switch - 5625-I...
Overhead light stays on all the time on craftsman garage door opener
Hello. If the light stays on all the time check these:
A. The light time delay on the opener will keep the light on for approximately 4-1/2 minutes after the system has be activated, then will turn the light off automatically.
B. If the opener has a worklight switch (which is supplied only with a four-function wall console), slide the switch to "OFF" position.
C. If the opener has a pedestrian switch (which is supplied only with a four-function wall console), the light will stay on for 4-1/2 minutes after the pedestrian door has been opened.
Mar 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I remove the door panel on a Ford F250 Supercab. I'm trying to find the switch for the ''doors adjar' light which won't go off and subsequently keeps my dome and outside bed light on and draws down...
the door adjar switch is the problem. the cargo light stays on until 35mph, as well as the overhead dome light. i just took the bulb out of the dome light and dont worry about the cargo light. it stays on for 30 min after the truck is turned off if the switch didnt trip properly. it shouldnt cause any problems as long as your batteries are good. i havent replaced the switch yet but it should be on the part of the door by the latch. get the replacement part and do a visual I.D. when you get the panel off. then replace it. the sensor is only 14$
Mar 03, 2010 | 2003 Ford F250 Super Duty Crew Cab
The overhead lights do not work when the door is open The lights work when turned on manually.
Check on your overhead lamp switch. There are 3 positions-off,on, and door operated. The dash control for the dashlights may overide the switch that is on the lamp fixture. That is why you can turn it on from the dash and not the door.
Oct 26, 2009 | 2000 Mercury Sable
Main fuses for the horn and air bag
Fuse #8, #18 and #22.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 02, 2009 | 2004 Dodge Intrepid
APW Wyott C*Radiant, Lighted Single Overhead Warmer - 18''L - Remote Toggle - Low Wat Logo
98 people viewed this question
Top APW Wyott Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an APW Wyott Electrical Supply Expert? Answer questions, earn points and help others
