Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
MY FLASH DRIVE IS WRITE PROTECTED, BUT THERE IN NO SWITCH?
  • 37 Answers
The problem in jetflas bios software
Posted on Dec 11, 2009
PNY Attache 64GB usb flash drive Disk is write protected
Normally I'd make something this simple the very first step. Some USB flash drives come with mechanical switch on them that put them into Write Protected mode.
There can be very small slider switch.
And if this is the case, then you must move the switch to unlock position.
Source: http://www.rescuedigitalmedia.com
Oct 01, 2012 | PNY Attache 64GB USB Flash Drive
Cannot format flash drive.... receive message `disk is write protected`
Usually there is a small switch or colored slide which flips between write protected and writable. If there is no switch it may be the software that is on the drive is preventing the format, if this is the case you may need to use a boot disk like Hiren's boot Cd to format it while not booted into Windows.
Mar 15, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My flash drive kingston 8 gb is write protected. how can i open my flash drive?
Hi.
Try these steps.
Carefully switch the write protect tab to Write enabled when inserting the flash in the usb "PC".
try using it. This happens mostly when you are inserting the usb, the tab is pushed to Protected mode without noticing.
If that doesnt work, i suggest you buy a new flash from different brand and less GB.
Good Luck
Nov 15, 2010 | Computers & Internet
How do you stop a pny 4gb from being write protected
A flash drive should operate just like any other drive. There is not write protect switch on it like an sd card. But, if the permissions have been set to be write protected on a given file or folder on the flash drive, then one can remove it through the control panel.
Or remove and replace the flash drive and make sure it has the latest driver running it.
Good luck on this operation.
Oct 23, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
File allocation showing 64.0GB, Not formating
If you inspect the Flash drive, you will see a little sliding switch on it. Slide the switch to the other side. Now, try inserting the Flash Drive and you will have write access.
Jun 28, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to Unprotect a Write Protect Flash Drive
how to unprotect a write protect my flash drive & i cant copy paste any of my files to my flash drive it gives an error
error drive not found
Oct 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
REMOVE WRITE PROTECTION
Look for a small switch underneath or at bottom part of flash drive, switch it to the other side then try reformating it. just look on the sides of flash drive.
dont forget to rate pls
Apr 09, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
Flash drive write protected can't move files
a small lock is presents in side of your flash drive ,u just change the current position of this lock
done,now try to copy or your work
regards prasanna
Mar 06, 2008 | Electronics - Others
Electronics - Others Logo
71 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
