Question about Toshiba TW40F80 40" Rear Projection Television
Irremovable gray bars
I can't change from the 4:3 ratio on the remote or in the menu. Those gray bars are driving me nuts. Any thoughts?
Press the demo button on the front of the TV, when the screen changes to theater wide mode turn off the TV with the power switch on the front of the TV itself then back on with the same switch, the setting will be saved in memory. I have to do this with my TV every time the power goes out in my apartment.
Posted on Jul 30, 2008
How do I change the aspect ratio?
bring up the on screen menu, find the aspect ratio and used the volume buttons to adjust to correct ratio, go ok then exit
Feb 15, 2016 | Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Sony kv-32hs420 screen mode doesnt work
Display ratio usually is a setup choice but bear in mind that old movies and old TV programs will display in 4:3 ratio. Remotes usually have no control over screen size.
Dec 28, 2013 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Gray bars on tv
when the screen ratio is different than the pic ratio, the tv uses gray or black bars to hide the difference, this is normal
Mar 07, 2013 | iPhone Apps
There are black bars on the sides of the picture its like the opposite of wide screen movies
Press the "Format" or "Aspect Ratio" or "Wide" button on the remote or look for these options in the display section of your menu. Note that this will normally change only analog signal aspect ratio.
Apr 26, 2011 | Televison & Video
I have a 50" Plasma
Hi, the aspect ratio is set incorrectly for the source material or the screen is simply set to 4:3 aspect (old TV size) manually. There will be a menu function or an aspect button on the remote for doing this. Set it to auto which is usually good enough for most viewing though the ratio may change during adverts and back again for the film on tv watching. This can be annoying so when on tv mode observe the ratio set when the film is on and manually set this ratio, usually 16:9. The display will normally tell you the ratio setting at the point of change so you can do this. I hope this helps.
Steve at Olive Country Computers in Spain
Feb 19, 2011 | LG 50PX5D 50 in. Plasma HDTV
Aspect ratio problem
enter in the menu and change background to black.
Apr 24, 2010 | Hitachi 53FDX01B 53" Rear Projection...
I have a runco pl 50dhd aspect ratio problem
Jeff, make sure to check the satellite receiver's set up menu it also has ratio adjustments the need to be set for 16:9 or whatever ratio your comfortable with. Good luck !
Nov 24, 2009 | Refrigerators
Televison & Video Logo
143 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
