Question about LG enV VX9900 Cellular Phone
Phone returns to main screen when navigating through the menu
I just got a new vx9900 and when I navigate through the menu, it continually flips back to the startup screen, and I lose whatever work I was doing--entering new contacts, etc. the pattern is random and not just after a long period of time.
The movies want play
  1. Test your Internet Connection
    1. From the PS3 main menu, navigate to Settings.
      • If you're not already at the main menu, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Select Network Settings.
    3. Select Internet Connection, and verify it is set to Enabled. If it's Disabled, make sure to select Enable.
    4. Select Internet Connection Test.
      • If you are able to connect to the Internet, check your date and time settings.
      • If you are unable to connect to the Internet, you may be having network connection issues.
  2. Refresh your Netflix Iogin information
    1. Begin from the PS3 Home Screen.
      • If you're not already at the home screen, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Navigate to the TV/Video Services section and highlight Netflix.
    3. Press X.
    4. Immediately after pressing X, press and hold both Start and Select and continue to hold them down until a message appears asking Do you want to reset your Netflix settings and re-register?
    5. Select Yes.
    6. Enter your Netflix email address and password.
  3. Reinstall the Netflix application
    1. From the PS3 Home Screen, navigate to the TV/Video Services section and highlight Netflix.
    2. Press the Triangle button on the Playstation controller.
    3. Select Delete.
    4. Select Yes.
    5. Download the Netflix application to your PS3.
    6. From the PS3 home screen, navigate to the TV/Video Services section and select the Netflix icon.
    7. Select Yes on the Are you a member of Netflix? screen.
      • You may be prompted to sign in to your PlayStation Network (PSN) account first.
    8. Enter your Netflix email address and password.
  4. Troubleshoot your Internet Connection
Oct 22, 2013 | Netflix
Can i stop the alcatel one touch 665 from playing a tone when i open and close the clamshell
Goto Menu then Profiles you see a red dot on General. Press options on lower left of screen and Edit. scroll down to Flip Beep and click it then scroll to Silence and press Select on lower left of screen. It worked for me.
Nov 20, 2011 | Cell Phones
How to reset samsung s w299
Restore factory default setting
1 Find "Reset settings"
  • Press the Navigation key to access the main menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Reset settings and press the Navigation key.
2 info.png Restore the factory default settings
  • Tick the required settings by pressing the Navigation key.
  • When the box next to a menu item is ticked (V), the setting will be reset.
  • Press Reset.
  • Press the Navigation key to confirm.
  • Key in the phone lock code and press the Navigation key.
  • If it is the first time you use the phone lock code:
  • Key in the phone lock code again and press the Navigation key.
  • The selected settings are reset.
3 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Samsung c3050 phone white screen
Different Samsung phones has different methods to reset to factory default settings, today I will give you the tricks about how to reset Samsung C3050. If there is something wrong with your Samsung C3050 and make your handset slowly, the best method is to reset it.<
p>
While restore your device to factory default settings will delete all the data you saved before, and then your cellphone will be quicker than before. So you should transfer the useful information to the memory card or computer, then when you finish resetting Samsung C3050, you can transfer them back. So back up first.
-Press the Navigation key to access the main menu.
-Scroll to Settings and press the Navigation key.
-Scroll to Reset settings and press the Navigation key.
-The first time you use the phone lock code, key in a code of your own choice.
-Tick the required settings by pressing the Navigation key.
-When the box next to a menu item is ticked (V), the setting will be reset.
-Press Reset.
-Press the Navigation key to confirm.
-Key in the phone lock code and press the Navigation key.
Note: if it is the first time you use the phone lock code, key in the phone lock code again and press the Navigation key.
-The selected settings are reset.
-Press Disconnect to return to stand-by mode.
Please take note: if reset is not the best solution, I would strongly suggest to contact your manufacturer.
May 13, 2011 | Cell Phones
Lost my internet, wont load so need settings please
  • Navigate to your cellular provider's website or call its customer service line. Access the "Support" section of the website or ask for the technical support division. Find the "Access Point," "MMS" and "Wap Gateway" settings and write them down.Power on the HTC phone and then press the soft key on the left side to bring up the main menu screen. Scroll down through the menu and highlight the "Settings" option. Press the square button at the center of the phone to access the settings menu.Choose the "Connections" option from the settings menu. Scroll down through the new list that will appear and choose "GPRS." Highlight the "New" option and press the center button. Choose "Connects To Internet."Scroll down to the "Internet" heading and choose "Change." Key in the Access Point that you wrote down earlier. Scroll down and press "Done.Navigate back through the menu to the "GRPS" option. Press "New" again, and this time, choose "Connects To Wap." Choose the "MMS" option. Key in the MMS settings you wrote down earlier.Return to the main menu screen and then select "Messaging." Highlight "MMS" and press the right soft key to bring up a second menu. Choose "Settings," and then choose "MMSC Settings."Press "Edit" and enter in the "MMS" settings again. Scroll down to "WAP Gateway" and enter in the information you wrote down earlier.Power cycle the phone by turning it off and then back on to complete setting up the WAP settings.
  • Oct 01, 2010 | HTC Cell Phones
    My phone dect 6.0 uniden rings when someone calls but will not dial out
    Hello :
    Maybe you need to program the phone .
    Here I'll tell you how :
    1. Press the Down main navigation button and press Menu/OK. The main navigation button is in the center of the keypad and is cylindrical in shape.
    2. Press either the Up or Down main navigation button until "New Entry" appears on the display.
    3. Press the Menu/OK button and "Enter Name" will appear on the display.
    4. Enter the name using the keypad. Enter the names the same way you would enter text in a text message on a mobile phone. For example, to enter the character "H," press the 4 digit twice. Use the labeling on the buttons to guide you.
    5. Press the Menu/OK button after entering the name and "Enter Number" will appear on the display. Enter the phone number using the keypad.
    6. Press the Up or Down navigation button to select "Save" or "Go Back" and then press Menu/OK. The entry is now programmed. Press the goodbye button; it's the button with the phone icon on a cradle.
    7. Press the Down navigation button and the first alphabetical number is displayed. If you keep holding the button, the phone will scroll through your phone book alphabetically.
    8. Press the button with the phone icon on it (not the goodbye button) to dial the number associated with the phone book entry.
    I hope that will help .
    rate if useful please !
    Feb 22, 2010 | Uniden DECT 6.0 Cordless Telephone...
    Sansa 260 Won't Let Me Navigate Back to Main Menu
    The power button is also the Menu button - click and release once while the player is on, and see if it gets you back to the main menu. Or press the left arrow key and see if it will get you back to hte previous menu.
    -Tha Mp3 Doctor
    Feb 21, 2009 | SanDisk Sansa e260 MP3 Player
    Navigation screen switches to menu screen w/out touching it
    go to MENU --> SETTINGS --> DISPLAY --> there u can switch off the navigation key icons.
    May 25, 2008 | Tomtom GO 720 GPS Receiver
    Navigation aint working
    Follow this: 1. Go to Settings & Tools. 2. Select option 5 (Phone Settings) 3. On next window select option 5 again (Location) 4. After the selection is made you should see 2 selection options. a.) Location ON & b.) E911 only. 5. If the selection is on "E911 only" your Navigation system will not work. Change the election to "Location ON" and after selecting this option, exit and go to Navigation.
    Aug 25, 2007 | LG enV VX9900 Cellular Phone
    LG enV VX9900 Cellular Phone Logo
    Top LG Cell Phones Experts
    skiffy99
    skiffy99
    Level 1 Expert
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
