Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Vaccum brush not working. Filters clear of debris has been smoking will not **** anything up help! I cleaned the brush up, cut hair out, etc. Still the brush will not turn and it smokes a little, is this a belt problem?
  • 701 Answers
Yes you need to change the belt. Here is a link to the belt you need and to a manual you can view:
Bissell Lift-Off Revolution Belts and Manual
Posted on Dec 11, 2009
Why won't my shark navigator cordless vacuum pick anything up?
Sometimes everything seems to be fine. The brushes turn, but if the brushes aren't cleaned of hair, rug tangles and so on, the brushes on the vaccum get filled and it won't puck up anything. ON THE OTHER HAND if the brushes are clean, did you check all your hoses from thr base of of vaccum where things get sucked up to the bin?
Jan 27, 2016 | Shark Vacuums
My brush stop working
Barring any electrical failure or loose plug the most common cause for the vacuum brush to stop turning is belt clogged with debris or string.
Unplug the unit and check the brush for string or debris (Hair) wrapped around the pully on either end. Clear this and check the belt to make sure it has not broken, stripped or simply slipped off. Usually the bottom plate is held on with just a few screws. Easy to remove and check Belt slipped off or stripped replace. Belt slipped off you can sometimes put back on and be vacuuming in no time.
Anything wrapped around the spindle a pair of needle nose pliers comes in real handy here. If you have snagged a rug, sheet or sock etc.. check the manual for a reset button. Some vacuums have this and all it takes is clearing the chute then resetting the switch. Good luck hope this helps!
Apr 03, 2014 | Vacuums
Vacuum leaves a trail of dirt
There's a small hole in the center front on the bottom by the brush. Its clogged with hair etc. If you stick your finger in there and remove the debris it will work fine. This just happened to mine.
Apr 06, 2012 | Bissell Lift-Off(R) Revolution(R) Turbo...
How to clean
There are 2 Filters that should be washed every 3 months. they are labeled as filter A and Filter B. They only neet to be washed with water. if you use any type of soap or cleaner it will actually damage the filters and they will need to be replaced.
Another part of the vacuum that can be cleaned is the clear bin assembly. REMOVE it from the cyclone before cleaning it. DO NOT get the cyclone wet. it will damage the machine. but again just water and a rag on the bin assy will work great any type of cleaner will actually cause the bin to get foggy.
The only other part to be cleaned is the roller brush. what i would recommed is to take a box cutter, and to cut the length of the roller. all of the hair and fibers on there. then turn the roller brush 180 degrees and cut it again. then turn the vacuum on and vacuum with it for a minute and the debris from the roller brush should be gone.
Sep 17, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Beater brush
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Make sure brush switch on the handle is on.
- Check the belt through the clear brush cover. If this appears damaged or broken, take your machine to a local BISSELL Authorized Service Center to have it replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Brushes will not turn . I put new belts and stil not working
Since you've replaced the belt, I believe that the roller is not functioning dues to debris or hair or bad bearings. See if you can turn the brush with your hand using moderate pressure. If not you need to remove the roller bar and see if there is anything like hair or string keeping it from spinning (sometimes you can remove the debris without removing the roller). If the bearings are frozen, you can spray them with a lubricant and try to free them up. If this fails, then you will need to get a new roller. I would also make sure that your filter is clean as this will cause the brushes not to turn on some vacuums although I don't believe yours is one of them. Hope this helps. Good luck!
Mar 16, 2010 | Bissell 8910 ProHeat Clear View Upright...
Burning smell
Have you checked the the hoses are free of debris?
Is the setting for floor on when you are vacuuming the carpet.
Turn id on an see if it will **** up some pennies.
Use the hose for that.
Check for string hair, etc cought in the brush.
Use the small pick knife that should have came w/ the dyson to cut away and thing caught in the brush.
Hope this helps.
Sketchlab.com
May 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Jan 03, 2008 | Hoover U5507900 Elite Rewind Bagless...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
389 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
