Question about Canon PIXMA MP160 All-In-One InkJet Printer
When i start printer E 7 2 error messge is displaying
  • cbigirish May 11, 2010
    what is the error message?
    President:
  • Canon Master
  • 1,447 Answers
Probably It show 2 (two) kinds of signal or error message.E2 or E7.
just problem E2 mean no insert recording paper.
Problem solve: when show this error press color key or black key then try to feed paper this printer.
E7: when show E7 some fine cartridge are not install properly right position.
Problem solve: follow mark where install color and black cartridge.
Posted on Dec 13, 2009
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Mar 07, 2013 | Konica Minolta bizhub C250 All-In-One...
LSU error shows in display panel, please help me and give solution for that problems.i dont get print or scan .....please prompt reply
im not sure what this error messge is LSU
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 09, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Display messge cru fuse error
Normally that means the fuser module has failed.
You can order and replace it yourself, I believe they are about $100.
That's what I paid for the last one I replaced.
You can call 1-800-835-6100 and order one.
All you have to do is remove the 4 screws that hold the back cover on, then remove 2 or 4 screws that hold the fuser in. Unplug a couple of plugs and slide in the new fuser. It is really an easy replacement.
Mar 31, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
My 2600 laser printer have 55.1 error message its not working.
DC Controller error.
Turn printer off for 60 seconds. If it's plugged into a surge protector, plug the printer into a wall outlet. Power it on. If it works - good. If not check the firmware version and upgrade it if needed. Other wise replace the DC Controller.
Jan 11, 2010 | HP Color LaserJet 2600n Printer
My ccalculator won't graph anything. I get the error messge Inval
Press the 2nd button, then the plus button, then 7, then 1 and then 2. This will reset your calculator to factory settings
Jul 23, 2009 | Texas Instruments TI-84 Plus Calculator
Di251 error code
most popular solution is you resigin your job hahahah
Jul 11, 2008 | Konica Minolta DiALTA Di200 Copier
Error messge on my brother DCP
You have to open the printer. The error means that either the encoderstrip isnt in good position or the encoder strip is stained with ink or the purgecam cant work well.
Read my solution here what to do:
http://www.fixya.com/support/t226406-keep_getting_message_unable_print_see
Oct 31, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
1,061 people viewed this question
old marine
old marine
