Question about Samsung SF-5100 Plain Paper Laser Fax
How to enter the correct date time - Samsung SF-5100 Plain Paper Laser Fax
  • Samsung Master
  • 1,316 Answers
Enter in the functions mode and select data/time.
Posted on Dec 12, 2009
SOURCE:
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
Sep 02, 2014 | Google Computers & Internet
Tip
How to adjust the LCD's time and date on Logitech MX 3200
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
on Nov 10, 2008 | Logitech Cordless Desktop MX3200 Laser...
Date and time not saved
After the warming up machines wants the Date and time.
first you press the stop button then enter 0101 followed by "enter" button. after one mints you machines display shows
"ready 100%"
if you are switch off the machines more than 7 hrs. again ask the date and time , then do the same steps above.
if you wants to enter the correct date and time pls. enter the month as first , then date , then year. suppose you want to enter today's date
like " 06012014"
ok....
Mar 19, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How to change the time
You can find the full manual here:
http://www.obfs.uillinois.edu/common/pages/DisplayFile.aspx?itemId=918000
But here's the part about changing the time:
System Reset-DATE or TIME
To change the terminal Date and/or Time:
1. Press the More function key.
2. Press the green Enter button until the terminal screen displays Other Set Up.
3. Enter the password (last six digits of the Merchant ID# or 998877).
4. Press the Enter button.
5. Press the More function key.
6. Press Enter until the terminal screen displays Date/Time.
7. Press Enter for Date (MMDDYYYY), enter the correct Date, and press Enter. Go directly to Time, and bypass Date, by pressing Enter twice.
8. Press Enter for Time (HHMMSS), enter the correct Time, and press Enter.
9. To Exit, select the red Cancel/Clear button twice.
Mar 20, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Please can you tell me how to change time and date. thank you. Wendy
The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
Start/Enter. The display asks you to choose a date format.
3. Press Start/Enter.
4. Press left arrow or right arrow until you find the desired date format, then press
Start/Enter.
If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
The display shows the currently set time and date using the selected date format.
5. Enter the correct time and date using the number keypad.
Day = 01~31
Month = 01~12
Year = four digits
Hour = 00~23
Minute = 00~59
You can also use left arrow or right arrow to move the cursor under the digit you want
to correct, then enter a new number.
6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
The display shows the time and date you have set, then returns to
Standby mode.
06-25-1999 12:30 ('USA' type)
Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
My Samsung Laser MFP SCX-4X21 SERIES ALL-IN-ONE WILL NOT PHOTOCOPY.
Hi again!
I'll repeat the solution for everyone's info:
When "Out of Range" error message appears, it means the time and date aren't set correctly! You have to set the correct time and date for the device to function.
To do this:
  1. Press Menu until “Machine Setup” appears.
  2. Press the scroll buttons to display “Date & Time”, then press Enter.
  3. Enter the correct date and time using the number keys (date format: month, day and a 4-digits-year).
  4. Select “AM” or “PM” for 12-hour format, using the # or * keys.
  5. Press Enter when done.
PS: You are kindly requested to rate the chat session we had recently. Thanks!
Mar 19, 2010 | Office Equipment & Supplies
Setting date and time on HP office jet J4580
Set the date and time
  2. Press the Left (c01185108.jpg ) or Right
    (c01185072.jpg ) Arrow button to select Basic Setting , and then
    press OK .
  3. Press the Left (c01185108.jpg ) or Right
    (c01185072.jpg ) Arrow button to select Date and Time , and then
    press OK .
  4. After Enter
    date
    appears on the control panel display, use the keypad on the control
    panel to type the date in the correct two-digit format, MM-DD-YY (01-01-10).
    After entering the date, press OK .
  5. After Enter
    time
    panel to type the time in the correct two-digit format, HH:MM (10:15), and then
    press the Right (c01185072.jpg ) Arrow button
    to switch between AM and PM . After entering the time, press OK .
Aug 21, 2008 | HP Office Equipment & Supplies
Setting the date and time on a LG LDP-7016D/7024D
All you have to do is:
Go to the main attendant phone, press Trans/Prog, then 0 for attendant, 4 for time and 1 for change time /date. Enter in the correct date and press OK, then enter in the correct time (in 24 hour format) and press OK. The time and date should now be correct!
Mar 11, 2008 | Motorola Mobility C51 SD7561 Phone
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
Samsung SF-5100 Plain Paper Laser Fax Logo
52 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
