Question about HP Vs17 17" LCD Flat Panel Monitor
Sound in right speaker only
I get sound thru the right speaker only. I have gone to control panel sound and tested and adjusted but still only from the right speaker.
I have an hp pavilion a1720n computer.
Can anyone offer advice to fix this problem?
  • iJonathan May 11, 2010
    what if there's COMPLETELY no sound? at all.
    Novelist:
  • 139 Answers
Do you have stereo headphones available? If so, try plugging the headphones into the computer. If both headphone speakers work then the problem is either in the monitor or the audio cable. If only the right headphone speaker works, then the problem is in the computer....probably a bent or broken contact in the audio output jack, or perhaps an incorrectly placed sound jumper on the motherboard.
Try to find another sound jack...for example, if you're using the sound jack on the rear panel...is there another one on the front of the computer?
Are you using the correct type of stereo sound cable? There should be three metal electrical contacts on the sound connector....a metal tip, a separate metal ring, and the metal sleeve. If there is only a metal tip and a metal sleeve with no ring...then you're using a "mono" cable that will only support one speaker.
If the cable and computer are ok, then your monitor probably has a problem with it's left speaker. You'll need to take it to a qualified computer or tv repair technician to track down the exact cause and repair it.
Posted on Jan 20, 2008
Sound no longer works seems as if the software for it is gone?
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 26, 2011 | ASUS Computers & Internet
My volumn is not coming thru the speakers
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
hope this helps
Jan 13, 2011 | Systemax Tiger (SYXS-DC-1000) PC Desktop
My rear speakers are not working now. Ran a test tone. Went to control panel to make sure the speakers were set correctly. I presses the test tone button to reset freq. Pressed tone test and connect...
Here is a guide to the sounds on a computer
hope this helps
Jan 13, 2011 | Dell WL6000 Computer Speakers
My front right and subwoofer makes sound, but all of the other speakers produce no sound. And during the test all of the sound from the other speakers come from the right front
if your computer came with a motherboard disk the sound drivers could be on it
((appropriate speakers)) or audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 30, 2010 | Logitech X-530 Computer Speakers
No sound out of speakers diagnostic button does not produce test tone,and right main speaker control flashes PROLOGIC. I have heard the motorboat sound coming from the subwoofer,but no sound now,green...
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
Dec 18, 2010 | Altec Lansing ADA 885 Computer Speakers
I had sound on computer when i put on windowsxp pro sound gone
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 05, 2010 | EPoX (EP-8KDA3J) Motherboard
I HAVE GONE THROUGH EACH STEP OF THE TROUBLESHOOTER, AND THE SPEAKERS ON MY TOSHIBA SATELITE A25-S279 WILL NOT WORK.
if your computer came with a disk the sound drivers could be on it
hope this helps
Nov 30, 2010 | Toshiba Satellite A25-S279 Notebook
No sound thru speckers
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 22, 2010 | Computers & Internet
My laptop's audio has stopped working, and the audio area says that the speaker is working and the sound is on, but nothing plays, not even the test tone. I think it is a driver issue. The speakers are...
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
or
hope this helps
Nov 11, 2010 | Computers & Internet
HP Vs17 17" LCD Flat Panel Monitor Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
