Question about Baby Lock Ellure
Babylock ellure I took my machine into the repair shop and now the bobbin won't wind and it is always telling me to raise the lever and it is already up. I live a long way from the dealer and am unable to go get them fixed. Is there a book that shows me how to repair these problems. My e-mail is Thanks
  • Anonymous Feb 01, 2008
    I too live a long distance from the closest babylock dealer - I need to be able to fix some of these issues myself. Is there a more detailed manual?
I asked MY tech yesterday after driving 8 hours to aone about the manual, I was told the techs do not want ANYONE into the machines because of the computer inside. I to need a service manual to fix a cutter problem. Why in the world do we continue to purchase macihnes that are unserviceable by us, the owner? because we love to embroider :) if anyone finds a manual for the ellure please let us all know :)
Posted on Feb 28, 2008
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
presser feet tutorials,
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
Babylock frozen tight its a eklure plus only used 6 time I've check bobbin cade changed needle although it was fine shut it off and turn it on. Bobbin winder on right side. It threw up a safety warning...
Sounds like it's time for a visit to the repair shop Babylock Ellure
is a fairly nice machine, it will be worth it...
Embroidery Services
San Diego, CA
Nov 23, 2014 | Sewing Machines
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
How do i remove cover
Lots of screws, then lots of clips to break off when removing the shells, then lots of fine cables to damage. Then a very big repair bill.
Save yourself a headache and a lot of money. Get it looked at by a trained Brother or Babylock tech. Brother makes Babylock machines so getting it serviced by a Brother shop because Babylock shops pay roughly 30% more for parts than Brother shops.
Feb 27, 2014 | Baby Lock Ellure
CONSTANT Check upper thread warning on a Babylock Ellure
try changing the needle
check for burrs on the needle plate and in the bobbin area
if the problem persists then the machine may have to be checked
Nov 26, 2012 | Baby Lock Ellure
How do you replace the spool pin on a babylock ellure sewing machine
Place the cone of thread on your right, at the back of the machine. Bring the thread up and behind the bobbin winder spindle. (where the bobbin sits) Place the largest spool cap on the empty horizontal spool pin and take the thread through the hole of the spool cap. From this point thread the machine normally. This and many other common questions are found on this link click here If you have any further questions message me back Thanks Rick
Sep 15, 2011 | Baby Lock Ellure
When winding a new bobbin, the bobbin itself is breaking in two. (splits in half, the top and bottom split apart). It seems logical that there is too much tension perhaps. It happens almost at the end...
There's really no way to increase the bobbin winder tension. Check to see that you have it threaded correctly for bobbin winding. There should be just a little bit of drag on the thread as you pull it over to prewound it on the bobbin.
May 03, 2011 | Brother PE-150V Computerized Sewing...
I am a beginner sewer, I just purchased the Emerald 203...I can't remember how to get the bobbins threaded, I looked in the manual, but it doesn't say how to thread it or how to thread a bobbin, which is...
The Husq Vik. machines have a raised white arrow that guides you in threading and winding bobbins. There are 2 ways to wind a bobbin. The one that I prefer is by threading the machine.
Begin by raising the needle to the highest position. This is done by turning the fly wheel towards you until the needle is at highest point.
Next, Place your spool of thread on the thread spool, with the thread coming over the top like a roll of toilet paper. Make sure you have a spool cap at each end of the spool. (your mannual will tell you what the parts are if you do not know what I am talking about).
Next, take your thread to the left, you should see a "track to follow". You will go left for a very short distance, then straight down (still following in the track), when you get to the bottom of the track, you make a "u-turn" up moving the thread to the take-up-lever. If you do not see the take-up-lever, you do not have the needle in it's highest position. Hook your thread around the take-up-lever from right to left.
Then follow the track down to the needle. You have a thread guide that hooks to the left just at the top of the needle - slip the thread in that guide by moving left to right. Thread the needle from front to back.
You should have it threaded now and ready to wind a bobbin. Simply take the thread under the presser foot and to the right - make sure the presser foot is raised. Also, always make sure to use a metal, not a plastic, foot when using this method.
Hold your bobbin with the writing side (crown on it) facing up. Wrap your thread around it clockwise about 4 times. Place bobbin on the bobbin winder. (top far right of machine close to fly wheel.) Make sure it is snapped down.
Push bobbin up to engage and lock. Slowly step on foot pedal. Bobbin should begin winding. Do not wind too full. Leave about 1/16 around to allow the bobbin to move freely in the bobbin case.
If you always keep the bobbin with the writing facing up, you will never have to worry about getting it wound the wrong way.
Hope this helps
Feb 14, 2011 | Husqvarna Viking 1
I need to service my Baby Lock Ellure sewing machine. Any information would be helpful.
All you do is clean the bobbin area - no oiling unless stated in the maintenance section of the manual.
If you do not have a manual, the Babylock website may have a download.
Apr 25, 2010 | Baby Lock Ellure
Sewing Machines Logo
227 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
