Toshiba estudio 810 copier driver on server 2003 - is there a trick to adding a specific type of TCP/IP port and driver? Copier is actually Estudio 550 with GL-1020 controller, but working XP PC uses gl1020-w2kxpvista-32bit-2381-pcl6. Can't get 2003 to load this driver properly.
  • Tom Carpenter Dec 22, 2009
    In this case, I noticed a UNC to the IP (\\192.168.254.42) showed shared printers since it has a print server built in.
    I renamed the copier so they could get to \\eStudio\ and choose PS, PCL or ??.
    It should work for them, so I was lucky.
    They had been using a XP workstation to share it prior since their 2008 64bit servers didn't like it.
    The 2003 virtual server I setup didn't want to print either, even with several correct drivers.
    I've had problems printing to copiers when the TCP/IP port is detected as "Generic".
    (For example, some of the Konica Minolta copiers work better when a QMS Printer Port is set for the TCP/IP port instead of "Generic" when it doesn't detect type.)
  • 622 Answers
Your best bet is to goto driverguide.com and find the drivers you need or goto toshiba support and find the drivers for windows 2003 and install them... don't try to share drivers especially from a desktop to a server... bad idea... best from the opposite direction...
Posted on Dec 12, 2009
Testimonial: "Thanks. I had already moved on, but it's nice that someone wants to try and help. Happy Holidays!"
  • Norman Davis
    Norman Davis Dec 22, 2009
    if you are trying to run a 32 bit print driver from a 64 bit pc you will have problems...
How do I print via USB on a Toshiba Estudio 200L copier?
You might need to have an enabler, which will fix to your copier.
May 16, 2014 | Toshiba Estudio 200L Copier
I am looking for a downloadable installer of toshiba estudio 166 printer/ copier, scanner.. does someone know what site? thank you.
Click here to visit Toshiba support and obtain drivers for Toshiba e-Studio166/206 B/W Copiers.
Download "Viewer 2 Full Installer"
This package supports Windows 2000, XP, Server 2003, Vista, Server 2008, Windows 7 in 32 and 64 installations.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Toshiba e-STUDIO166 Printer
I need software toshiba 350 copier
I hope this link helps!
This the is the windows drivers/software for the Toshiba eSTUDIO 350 Copier.
http://www.top4office.com/drivers/toshiba-estudio-350-photocopier/
May 04, 2011 | Computers & Internet
Sorry, need the driver for toshiba eStudio 180s
you can download the driver at www.toshiba-sa.net under drivers good luck
Feb 20, 2011 | Toshiba Estudio 200L Copier
Linux print to eStudio 232 printer
Did u install the driver?
Driver can be downloaded at below link:
http://www.eid.toshiba.com/support/controllers/ebridge282-283%20series.shtml
Aug 05, 2009 | Toshiba e-Studio 232 Black and White...
Hi, I have one Toshiba e studio 200 that one is did not working as a printer now. Before that one was working. But yesterday i did the machine default setup. After that i did not getting the printer.
What kind of interface your estudio 200 is running ? GDI/parrallel cable or network?
If GDI, u need to make sure u installed the correct driver.
If network, make sure the IP address is static, network driver is installed properly.
Mar 28, 2009 | Toshiba Estudio 200L Copier
Reset fax data in toshiba estudio 350/450
how do I find my IP address for my Toshiba e-studio350
Nov 30, 2008 | Toshiba e-Studio 350 Copier
649 people viewed this question
k24674
jasbo
jasbo
