Question about Vizio L32 32 in. LCD HDTV
Power lite is on, no picture showing, not even a blue screen. Could it be a fuse, or something els.
  • 74 Answers
The only fuse I'm aware of would shut down everything if it blew.
If you have moderate electrical skills or know someone who does, check the output voltages on the power supply. You should have 5VDC, 12VDC, and 24VDC. The connectors are conveniently marked so this is easy to check if you have a meter.
If the power supply is bad, contact Vizio support. They can offer the lowest price for a replacement than anyone else I could find when I was looking for one. $82 sure beats the $180 others are charging.
Posted on Dec 19, 2009
SOURCE:
Toshiba Satellite c655 is only showing blue screen after powering up.
Could you describe what it shows? Usually it shows something like STOP or similar words. A picture would be even better
Jan 05, 2013 | Toshiba Satellite L305-S5933 Notebook
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
I can turn power on and i will get sound but no picture. I can get different channels up & down with sound only ,but no picture. It seems that the picture has totally failed as there is no on screen...
This can be caused by a main board failure or a t-con board failure. There is a fuse on the t-con that fails but it is not the standard looking fuse. It is an extremely small, surface mounted component fuse. You have to know what you're looking for to find it. It can be bypassed momentarily and if the picture comes back then the t-con is the problem for sure. You really ought to take it to a shop as this is not something that is easily diagnosed at home.
Aug 28, 2010 | Olevia LT42HVi 42 in. LCD Television
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Feb 17, 2010 | Nintendo DS Lite Console
Only used a few times and the power is on but nothing showing on the screen and theres no sound its a black ds lite
The reason the screen isn't showing-up is probably because of runny colors or blotchy colors permanently stained on the screen, even when the Nintendo DS Lite is OFF, my guess is that the liquid crystal display (LCD) is cracked. And also, there are multiple reasons for your speakers not working properly. The main reasons for the speakers not working would be the following;
  • Something small must have gotten wedged inside of the speakers.
  • A type of liquid and/or sticky substance leaked into speakers.
  • Lots of pressurized force on upper screen(which could have also caused the damage done to the screen).
What I would recommend is make an appointment with "Nintendo customer service".
Feb 16, 2010 | Nintendo DS Lite Black Console
HP md5020n does not have picture
UNPLUG IT AND IFF YOU CAN TAKE THE BACK OFF ,,AND CAREFULLY LOOK ALL IN THERE FOR A FUSE ,,SEE IF ITS BLOWN,,
May 15, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Nintendo ds NEED HELP
My DS touch screen is very light. If you turn look at a particular angle you can still see what is shown on the screen, but other than that, the screen looks white. I have already changed the touch pad and that was not the problem. Any assistance would be appreciated.
Thanks
Feb 04, 2008 | Nintendo DS Console
Vizio L32 32 in. LCD HDTV Logo
180 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
