Question about LG XBR446 DVD Recorder/VCR
LG DVD player USB port the message showing 'no file found
My LG DVD player can work witt 1.1 and 2.0 , but recently when try to view USB files I ge tthe error 'no file found'
What do I need to do, please help
dsom
  • 56 Answers
SOURCE: DVD player cant read DVD media
.Vob files contain audio, video and subtitles all together.However, most MPEG-2-capable DVD players don't support subtitle tracks. I guess your DVD player is in the mentioned majority. That's why you can only play them in your computer drive.
Posted on Apr 24, 2007
SOURCE: LST-3510A
Hello, I've been reading up on the LG LST, I got the same device. Two options that you may want to try (and there may be a third). 1st) Make sure nothing has happened to your DVI cable, make sure it is tight on both ends. Undo it and blow on the connectors and resecure it if need be. HDCP involves communication between the HDCP chip on your LST and the HDCP chip in you display. If you cable is loose, dog chewed or too long then it may be interfering with your HDCP handshake. 2nd) You should be able to go to RGB display option and dispay in HD over the same DVI cable. This was discussed much in the forums I have been reading about. I hope one of the above options helps you. In fact I hope the vacume or kids knocked the cable slightly loose and you are back in business after tightening it. The 3rd option would be to do a google search for LST-3510a and HDCP, you will find all kinds of solutions, work arounds and firmware update discussions. Good luck! Scott
Posted on Jun 08, 2007
SOURCE: Problems with LG MP3 Player (due to a mistake in the operation of the device)
I too have had the "Device Manager code 9001 see manual" message come up on my LG unit, after having upgraded the firmware. All my music and photos disappeared and the unit would lock up if I tried to record anything.
I decided to format the device (from the General Settings) and the error message doesn't come up anymore. All my stuff was gone so there was nothing left to lose. It seems to be working now. I hope this helps you guys too.
Posted on Feb 05, 2008
SOURCE: LG DVP7772 Portable DVD Player with Screen showing disc error
its aged and old, all pordable dvd players stuff up eventually, get a new one.
Posted on Aug 10, 2008
Benimur
  • 6966 Answers
SOURCE: Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 17, 2008
What do you do if an hardrive is connected to your lg DVD player an it’s cming up saying there’s no files
Is your hard drive detected by the DVD player? If not.. Its most likely not supported. You should try copying the files on a USB pen drive and then use it to view on your TV.
Dec 25, 2017 | LG Televison & Video
I have a DVD made 10 years ago whch plays on my PC (windows 7) when inserted into the DVD drive and also from windows media player. I want it to play from a USB for an 80th birthday coming up.
Your best bet is to:
1) Transfer all of the files from the DVD to your USB Drive. Then:
1) Download and install VLC Player on the computer you will be viewing the video on.
2) Plug the USB Drive into that same computer.
3) Find the largest file on the USB Drive from that DVD (details view click on size column, which will sort the list by size).
4) Right-click on file and choose: Open With... and choose the VLC Player to open it with.
If the first file you try this with, does not play, try the next largest file, and so on.
VideoLAN Download official VLC media player for Windows
Sep 01, 2017 | The Computers & Internet
My LG DP122 will play some AVI files from a USB device but not others.
figured this out, lg dp122 uses DivX Home Theater profile, so the technical specs of the video must match that.
Those specs can be found here: http://www.divx.com/files/DivX-Profiles_Tech-Specs.pdf
Jan 23, 2013 | LG DP122 DVD Player, Multi Format...
USB port on LG DN898 Isn't playing movies from flash drive. TV screen is showing that the USB port is being used but no files are showing and nothing else is happening.
certain files are NOT register from DVD, you must read your instr.manual. The format is not support, you must convert your movies and know format from your DVD accoring in your instru.manual download the instr.manua. go to www.fitness.manualsonline.com or www.retrevo.com
God bless you
Jul 20, 2012 | LG DN898 DVD Player
On my dp4000 dvd player, when I have shows on a USB (Disk on key) I only see 1 files per directory.
Most DVDs with a USB Input will not recognize directories.
All files need to be in the root directory to be viewed.
Jun 16, 2011 | Televison & Video
I can't get Terminator Salvation Blue ray to play on my LG BD370
Its a known issue. There is a firmware update available from the LG website. Download the file LG_BD_370M_UPG_LG_V7154.zip and follow the instruction from the website. It solved the issue for me.
Nov 30, 2009 | LG BD370 BLU RAY PLAYER
How to update
call 1-800-243-0000 and they will send you an upgrade
Feb 02, 2009 | LG Super Blu BH200 Blu-ray and HD-DVD...
Playing DIVX on an LG LH-RH3690 DVD recorder
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
Sep 11, 2008 | Yahoo YDP305 DVD Player
USB Port
I am not getting any sound from my koss model ks3101 through the speakers
May 30, 2008 | Philips LX3750W System
Unlock LG DVD
The following hack worked for my player. It works for most LG and Aiwa players too. To hack the player try this:
  • Power on player with no disc inserted and wait for "No Disc" message on screen
  • (using the remote) Press PAUSE
  • Press the numbers 314159 in order. (player should now show "COdE - -" the same as below)
  • Press the number of the region you desire ( 0 = any region, 1 = US&Canada etc.)
  • Press PAUSE
  • Power off the player for a few seconds..power back up and insert your DVD disc
Jan 08, 2008 | LG Televison & Video
LG XBR446 DVD Recorder/VCR Logo
573 people viewed this question
Computer Repairing
Computer Repairing
