Question about Intel Pentium III , 866 MHz Processor
When I start computer it goes to safe mode then again restart
When I start computer it goes to safe mode and restart again an again, I cant get the solution how to start this, I also check all the wires, but there was no solution
    Problem Solver:
  • 11 Answers
Hi... check the Keyboard some key r stucked. hold the F8 til it going to boot
Posted on Dec 12, 2009
SOURCE:
My computer stopped working in the regular settings, so i decided to do a factory settings restore, well it worked but now i cant get my computer out of safe mode, it automatically goes, no matter what i...
It only means that windows.ini was not successfully installed. You need to reinstall the operating system again or else your computer will be stuck on safe mode.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 21, 2011 | Dell Inspiron M5030 Laptop
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Netbook Wont Turn On!!!
Restart your computer and keep pressing F8 and choose safe mode from the menu
once you enter safe mode,click on start->settings->control panel->system and then device manager
and under display adaptors,disable your display card and then restart it again and see if it works
Jul 22, 2010 | Asus Eee 701Sd Notebook
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Acer aspire one
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
Mar 17, 2010 | Acer Aspire One PC Notebook
I cant seem to log on
try starting in safe mode. hold down f8 when you turn on your computer until you get a menu with the option to boot in safe mode. once you successfully log on in safe mode, restart your computer and the problem should be cleared. if not, we can explore further options.
Aug 14, 2009 | HP Pavilion dv9000z Notebook
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Vista activation
Restart your computer into safe mode.
Open RegEdit :
- Click Start, Run
- Type 'regedit'
- in regedit, search for "WGANotify" and delete any instances of it in the registry.
- restart your computer again, and return to safe mode.
- Click on Start, Search for Files or Folders, then search for "wga*.*"
- Delete the files that will be found.
- restart your computer.
Feb 18, 2009 | Microsoft Windows Vista Ultimate Edition
My computer is auto restart.so i cant do anything pls help
Did you install any new software/drivers? Do you have properly updated Anti Viru installed? Sometimes misbehaving drivers force windows to restart again and again.
(Presumming that you are using Windows)
Try to start the computer in "safe mode" by constantly pressing F8 while start up. Next screen will show the options available for starting the computer.
OPTION 1:Choose "safe mode" from the option. Please wait for a while it takes some time. Once there please use the "system restore" option when dialog box appears asking for you to choose the next action.
OPTION 2: you can follow a longer process if you want to know which driver is actually malfunctioning. Choose "continue with safe mode" and type "msconfig" (do not include quotes) a new window will apear, go to "start up" TAB and uncheck all the items shown there. And resart the system normally.Now, go to run again and type "msconfig" go to "start up" TAB and check one item from there and click "ok" and restart your system. Do this untill you find the malfunctioning Driver, once you get hold of the culprit (note down the name) and restart the system once again in "safe mode" and when you reach the "start up" TAB under MSCONFIG, uncheck the specific driver and restart. Your System should work fine.
If this does not solve your issue, you will need the Windows installation disc to repair you windows instalation.
Feb 02, 2009 | Intel D945GCL Motherboard
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
Intel Pentium III , 866 MHz Processor Logo
211 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
