Question about Brother Office Equipment & Supplies
Receive has replaced send on my on teleface 2820
"Receive" only when I punch start.
Can't get "Send"
Need help immediately. Thanjks.
    Champion:
  • Brother Expert
  • 270 Answers
Make sure the document is inserted 'deep' enough into the ADF. Make sure after inserting the document, the display shows 'key in the destination number & press start'.
Posted on Dec 12, 2009
SOURCE:
When i send or receive a fax their i a narrow blank space down the left margin of the fax. when I send copy to fax from my PC everything is fine brother intelifax 2820
Hi!Please just lift up the adf(where u put in the faxes)U should see a thin glass strip,Take a damp cloth and gently wipe out any marks that might be on there and have a look!The stripe should be gone!Good Luck!
Dec 08, 2010 | Brother IntelliFax-2820 Laser Fax
A particular business can receive faxes from me sometimes, but other times I get a strange beep and it doesn't go through. They receive faxes every day with no problems. I send faxes every day with
This is a problem on ther side. A lot of high volume companys dont admit this, insurance order etc most use pc based fax products to filter junk this can also cause probs
May 11, 2009 | Brother IntelliFax-2820 Laser Fax
Can not send out faxes
You have to get your phone line checked out .
Apr 28, 2009 | Brother IntelliFax-2820 Laser Fax
Cannot receive or send faxes
See user manual for setting ring sensitivity. This may be where your problem is. Hope this information was helpful!
Mar 12, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Fax 2820 gives message: Back Door Open
It could be that a tab is broken off of the door that trips a switch. Cheat the switch with a small folded piece of paper.
Dec 17, 2008 | Brother IntelliFax-2820 Laser Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Cant get or send faxes
fax machine rings busy, not able to receive or send faxes
Jul 18, 2008 | Brother IntelliFax-2820 Laser Fax
Cannot send faxex
Did you try to send a fax to a different number? Also are you sending to a local number? Most send problems are poor phone line conditions. If you have tried to send to several different numbers with no success, then you can assume that the LIU board needs to be replaced. It costs about $40.00 from Brother for the part.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 28, 2007 | Brother IntelliFax-2820 Laser Fax
Can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
Aug 01, 2007 | Brother IntelliFax-2820 Laser Fax
24 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
