Question about Water Heaters
Installed new compressor for waste water lift station and quincy 240 blows out water thru the air filter intake.
  • Water Heaters Master
  • 17,115 Answers
Intake valve is bad or missing. What is the exact model number?
Posted on Dec 11, 2009
My gas was turned off for 4 days. after being turned back on the pilot will light and the burner fires up but shuts of in 10 minutes
If heater has a sealed front door the air intake filter is probably clogged. Remove the door and vacuum out all the dust and debris in the inside. Then use an air compressor to blow down thru the filter and force out any dust caught in the underside of the filter. Reinstall assemble heater and relite. If problem continues replace the gas control. If unit does not have sealed door just replace the gas control
Jan 01, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
My smart water pilot is on but it is not heating the water tank
GE is Rheem.
Models change frequently.
Copy following link for troubleshoot resources by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Newer water heaters require frequent air intake cleaning.
To do this with Rheem requires removal of combustion parts, and then air compressor to blow out screen.
It is probably time to have a plumber give water heater a catch-up on recommended maintained, such as checking gas pressure, bleeding gas line, checking vent draft, clean combustion parts, clean air intake, check if gas control is working correctly.
Sep 03, 2012 | General Electric GE SmartWater Household...
Comes on for appx 20sec then gives code ao21
Before calling service technician, open following link for Rheem troubleshooting resources including error codes, Rheem chat and phone number, possible instruction manual, maintenance manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start point for troubleshooting.
Error code 21 is "malfunction of air intake filter switch"
Make sure air filter door is properly seated.
Make sure front panel is properly installed.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Aug 25, 2011 | Rheem Tankless Hot Water Heater...
We have a Richmond Tankless water Heater that is flashing between A1 and 21 and not heating the water.
Error 21 means the air intake cover problem.
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated.
Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Richmond is Rheem
Typical manual shows regular maintenance on page 29:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
The word maintenance is used throughout manual.
Tankless are prone to lime build-up and should be de-limed each year, and cannot be exposed to more than 11 grains of hardness in the water.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Rheem Tankless Hot Water Heater...
Model RTG-42PVP my display is switching back and forth between A1 and 21.
Use following link for Rheem tankless troubleshoot: http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
I believe error code A1 21 is malfunction of Air intake filter switch
Ensure air filter door is seated.
Ensure front panel properly installed
Feb 12, 2011 | Rheem Tankless Hot Water Heater...
Working on a 3yr old rheem water tank 22v50f1, pilot doesn't stay on, replace theromcouple and problem persist, cleaned air intake screen... what do ??? air intake issue ... any recalls... chimmey is not...
I would remove burner assembly and clean pilot orifice to make sure you are getting strong pilot flame. I would also check the position of thermocouple. If it is laying on bottom of combustion chamber I have had this make new thermocouples go bad.
Also check the height of flue where it goes thru roof. With the newer water heaters with bottom air intake I have had problems with the pilot being blown out due to no other way for air to escape if you have a downdraft. Flue should be higher then highest point on roof.
If all else fails I would replace gas valve. Hope this helps you. Thanks
Dec 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a well-x 250 the tank appears full of water. I cannot get any pressure in the top I tried pumping air in with an air compressor. right now I am draining the water out at just a trickle blowing air...
To get the water out so you can lift it knock a hole in the top next to the bend.then throw it in the garbage.250 is a big tank make sure you size the new one for your application.theres no fix $$$$
Mar 16, 2010 | Amtrol Water Heaters
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Mar 03, 2010 | Rheem Paloma Tankless Water Heaters...
Paloma ph24 has good pilot but when u turn on water it does not fire main burner
Thermocouple. cannot be tested get new & replace. They are not expensive
Jan 18, 2010 | Rheem Paloma Tankless Water Heaters...
Palaoma ptg-42pvn flashing a1 21 code
error code 21 is malfunction of air intake filter switch. You need to check and make sure the air filter door is properly seated and that the front panel is properly installed
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
19 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
