Question about RCA D52W19 52" Rear Projection Television
Will not power up
No green lite blink. fuse is ok, cp 150, cp 120, cp114, replaced..power cord ok . wher to begin..??
  • 9 more comments
  • vettek50 Dec 11, 2009
    yes there is power to the board. plz i think there is more of a problem and plz dont added your answer unless you know what you are talking about ,, thank you
    hey slinteriors :that was the most useless help yet!
    ther is power to the power convertor board..
    "the deflection board needs replacement " .. is that a conclusion without check all connection to the board?"
    i of you dont mind please answer these questions ??
    What is code 19? what is code 59? what is code 95?
    i have researched and require these question answered.. from there i can conclude my own diagnostic..
    dont be afriad to give a detail discription.. if this is not possible, please pass this request on to someone whom may know or has access to the infromatiom regarding codes..thks
    now that more like it !!! I have great respect replies like that. checking code 59 IR0001, and code 95 IR001 cant do,,that a programming issue . without software . can't be done..my best guess that the service people whom look at this shorted the deflection board. i did find power terminal from ac board connected at the wrong termainalon the deflection board. this indicates the board was short by tecky because after he complete his work he said that board was shorted.. telling me that i need new board..couldnt fix because these borads are unavailable..
    but thanks for your reply very good!
  • vettek50 Dec 12, 2009
    the ITC222, ac filter board as follows FP-400 is good, CP410 =160vdc..power is there just not 300volts . sorry but ther is no dp230 or ccp230 on this board or cp010 or f9400.
    the front lite is blinking, 9 times then pause 5 times, recycles, it may blink times first then 9 times depends what i started counting. This blinking is definetly telling me something. i just dont have the resource to determine.
    i answered your question and look forward to your assistance
  • vettek50 Dec 17, 2009
    ok run through the trouble shooting guide (dead set)you sent me..i replaced c150, c114.c120..replaced board. found burn through CL031 resoldered, tested the CAP seemed to be ok.. powered up...but power lite blinks once, pause, then 9 times. this indicates code 19, which may be the flyback control LL008..OK now What?
    CL031 did burn solder joint through board. i resoldered it fixing the board. as i said i tested the CL031..seemed to be ok...however this does not answer code 19.. any other ideas??
    when i depress the on button there is a short click sounds then button starts blinking,, if you want me to test HOT . tell where to measure?
    pin reads continuity in one direction then reverseing the leads on those same two pins there should be no continuity. i checked all hot points from ac filter board.. so now what???
  • vettek50 Dec 18, 2009
    i did all the trouble shooting i gonna, .. guessing a fix is too time consuming.. i an sure rca thompson know how to fix, without all the BS..the tv has good blubs and its found a new owner call the recycler.. done
  • RCA Master
  • 8,617 Answers
If youre not getting a power light then its most likely the AC main filter board ( Where power cords plugs into ) or if you do get a power light the deflection board needs replacement.
Posted on Dec 11, 2009
  • 5 more comments
  • Sonny Berry
    Sonny Berry Dec 11, 2009
    The ITC222 Chassis has a 19 error code which means Invalid chassis Code 59 is IR001 is not fitted, and Code 95 is IRoo1 err-12C Port driver can not be installed. I have worked on the ITC222 Chassis almost exclusively since they were first introduced, And if you hold the power button down long enough you will get 19 blinks. But thats not a diagnostic code. Without a chipper check II you cant retreve valid codes. The way to trouble shoot a ITC222 Or a ITC222A chassis is. If you dont get a power indicator light when you press power. Then trouble shoot the AC filter board. If the voltages are correct then its the deflection board which will require troubleshooting. The ITC222 chassis is very complex even for qualified TV repairmen without a Chipper Chgeck interface. I have givem advice based on my 30 plus years with RCA models.You asked where to begin and I responded. If you dont get a power light check the AC filter board first, If thats not the problem it has to be the deflection board causing the issue. No other boards will cause that symptoms.
  • Sonny Berry
    Sonny Berry Dec 12, 2009
    Ok here is how I troubleshoot the ITC222 if the led doesnt light I check CP010 for 300VDC if thats missing I check F9400 to see if its blown. If it is then suspect that DP230 or CP230 as they may be shorted. If you get 300VDC at CP010 then check to see if the 3.3 V and the 5 volt stand by are present. Then let me know what you found and I will assist you to locate whats happening with your chassis.
  • Sonny Berry
    Ok, do you have the schematics for the ITC222 Chassis? If not send me a email to slinteriors@yahoo.com and I will send you the service manual with schematics and I also have the troubleshooter for the ITC222 dead set which is what I always use. which will help you to pinpoint the problem.
  • Sonny Berry
    Sonny Berry Dec 17, 2009
    If Cl031 was burned, check the HOT as that will usually be shorted or open when the CL031 burns the solder joint. That cap can actually burn through the circuit board.
  • Sonny Berry
    Check the HOT out of circuit see if its open or shorted. Do you hear a short chirp when power is pressed?
  • Sonny Berry
    You have to remove from circuit then using the ohms meter check each two pin juntions twice by reverseing meter leads on any given two pins then recording the measurements. If there is continuity on any given two pins even after reverseing the meter leads the HOT is defective. same holds true if you get no continuity even after reverseeing meter leads the HOT is open and needs replacement. In theory a HOT is good if the center pin and either outside pin reads continuity in one direction then reverseing the leads on those same two pins there should be no continuity.
  • Sonny Berry
    Sonny Berry Dec 18, 2009
    Did you check the HOT transistor out of circuit? If so then I would check the diodes and resistors that are one the same ciruit as CL031 as one of the diodes may be leaky or a resistor can also increase in resistance.
"Still no power". After replacing cp114, cp120, cp130 and cp 135 on my RCA D52W20B, when powered on the green comes on along with a high pitch sound making several attemps to power on before completel
The whine is a short somewhere---+ and - are marked on the board for each cap if it is polarized---usually the - will have a shaded white mark on top of board--if you got one in backwards it can explode......
Apr 13, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
RCA D52W17 wont come on, the green power light goes on and off three times then stays off.
On deflection board CK capacitor cp 150 2200uf 16v use 25v if i is puffed up on top it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v for parts call Mats 1-800-628-1118
Nov 12, 2009 | RCA D52W19 52" Rear Projection Television
Have a hd52w56 when power up lcd blinks 3 times and then goes off... I have replaced the green tube(was cracked) and then was working . then the screen went green and the fuses popped, change the fuses and...
On your Deflection board it is the one on bottom to the left CK capacitors cp150 2200uf 16v if it is puffed up ont op it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v resolder all pins on FBT flyback transfomer.
Nov 10, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tv wont turn on but green power lite flashes 3 times if i use the remote or press power button on front of tv i have unplugged tv replaced the batteries in remote trouble started 2 weeks ago if i hold...
it sounds like youre describing a RCA HDTV which needs the CP150, CP120 and CP114 repair kit. You can get that repair kit at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Sep 22, 2009 | Televison & Video
Everything I read says if My GE Hdtv light is blinking 3 times and then going off it is the flyback. I just put a new one in. I took the board out and found CP 150 was domed real bad. Could this be the...
YES! THATS ONE OF THEM THERE IS 2 MORE IN SAME AREA THAT ALSO NEED TO BE REPLACED There is 3 capacitors 2200uf 16 v and two 220uf 35v they are Green with gold writing on them cp120 cp110? cp114,? cp150 Replace any capacitor that is puffed up on top.
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
Power light flashes 3 times then turns off. no picture or sound. model is a d52w19d. i need the parts numbers so i can replace them and fix the problem.
See if cp 150 capacitor 2200uf16v will be green with gold writing on it ,if its bad replace other 2 caps in same circuit different value 220uf 35v cp111 cp114
Dec 04, 2008 | RCA D52W19 52" Rear Projection Television
Overload
Hi
Your printer was pawered ON during the Lightening if yes then follow the steps, Try with the different power card if it having the same problem then most probably your printer fuse blown open the printer and check the fuse if the fuse are OK then please check with the service centres
Boopathy.T
Aug 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
RCA D52W19 52" Rear Projection Television Logo
559 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
