Question about U-Line 75R Refrigerator
U-line 75R was not cold. Shorting the two wires at the thermostat, the motor runs and starts to get cold. Replaced the thermostat, but it didn't run at all. Please help. Thanks
  • dnathome Dec 11, 2009
    How do you advance the defrost timer? I unpluged it and waited and then tried again, but it's still not working.
    Any other advise? Thanks
  • 93 Answers
This U-Line does not have defrost timer, check the wire connection on the thermostat or you may have a bad new thermostat.
Posted on Mar 02, 2010
    Scholar:
  • 39 Answers
There is a slight possibility that the unit's defrost timer just happen to be in defrost when you replaced the temperature control. Try advancing the defrost timer (or just let it sit for about 1/2 an hour and see if it comes back on). If you have more questions, let me know. Hope this helps!
Posted on Dec 11, 2009
SOURCE:
Goodman A/C, outside unit. I replaced fan motor, run cap, and start cap. Fan still not turning. Power is good, contactor appears clean to new. Slight humm from compressor. What next. Is there a...
If the compressor gets hot and cold on its suction and discharge lines, then try looking for a pressure switch on the wiring diagram or on the fan motor wires, and bypass it. This will test the motor once it has power to it.
If there is a pressure switch and the compressor does not get hot and cold on the suction and discharge lines, then it is probably out of refrigerant, it leaked out.
Nov 15, 2017 | Heating & Cooling
Tip
U-Line 75R: Replacing Thermostat when unit will not run
<span>I am reposting <b>Don Willis's</b> EXCELLENT but hard to find tutorial on how to replace a thermostat on a <b>U-line 75R</b> as a HOW-TO Since he spelled "refrigerator" incorrectly (Refidgerator), </span><span>Google cannot find it easily! I followed these instruction and finished in about an hour. </span> <span><br /></span> <span>Got the thermostat part on eBay from a venfor called Part Peddler.</span> <span>The U-Line part number is 2766-S, cost me about $30,shipped.</span> <span><br /></span> <span>Don's post follows, my comments in {} brackets: </span> <span><br /></span> <span>The light worked so it was getting power. </span> <span><br /></span> <span>I used an electrical tester (pencil like device I bought at Lowe's) to figure out that power was making it to the thermostat (black wire) but not after the switch (blue wire). </span> <span><br /></span> <span>To change the thermostat. </span> <span><br /></span> <ol> <li><span>Take covers off the front bottom (one flathead 1/4" hex screw) and back panel (about 10 flathead 1/4" hex screws) of fridge.</span></li> <li><span>Unscrew the old thermostat (2 screws). Leave black and blue wires on it so you will know where to put them on the new one.</span></li> <li><span>Take out glass shelves on inside. Unscrew back panel {note: there are spacers that will fall out} . There are 2 phillips screws {on nuts} that hold the end of the thermometer to back panel. {I removed one and loosened the other to free the "coil" thermostat) reach hand under the back panel and feed the thermometer back through hole and out back of fridge. You will notice a putty like substance that fills in the hole in the back where the thermometer gets fed through. Make sure you keep it to fill in the hole in the back. </span></li> <li><span>Feed new thermometer {coil} end through hole in the back {I found that using a Phillips head screwdriver to guide the coil through was useful} and install to back panel {using those two Philips screws and nuts}. </span></li> <li><span>Put the putty back in the hole from the back to insulate around it. </span></li> <li><span>Feed the electrical end of thermostat through bottom of fridge</span></li> <li><span>Take the wires off the old one and attach to the new one. </span></li> <li><span>Attach the thermostat to its mounting location </span></li> <li><span>Reinstall all the screws in the front and back and you are in business.</span></li></ol><span>Had a hard time finding someone to service it. They wanted $200 to come out to the house + parts and labor. The new thermostat cost $33 at All Brand appliance. I am from Mass and picked it up in Brockton. I emaile dU-line and they sent me the new part number. The allBrandappliance site had the old part number (2766-s) I am notan electrician and this was a few hours work.</span>
on Apr 10, 2011 | U-Line 75R Refrigerator
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 21, 2011 | Kenmore Dryers
Changed the thermostat, still no heat. Is there a valve of some sort in the heater hose lines or on the heater assembly that controls the hot water?
when the vehicle is cold take the radiator cap off and start the vehicle let it run with it on defrost at full blast until the vehicle gets to running temp,if there is still air in the system it will blow cold air if that doesn't work then check to see if the vacuum lines that run the blend door in the heater box have came off (depending on year)
Dec 28, 2009 | GMC Jimmy Cars & Trucks
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
My u-line 75rfb-00 refrigerator wont get cold the light comes on the motor sounds as if its working but it only gets cool not cold ?
Then you need to see if the compressor is running or is it the fan? You migh be hearing the compressor come on for a short while. The fan might not be running. Replace the fan if its not running
Sep 26, 2009 | U-Line 75R Refrigerator
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Aug 11, 2009 | U-Line 75R Refrigerator
Lighns on - nothing else
well i have a 75r also with the same symptoms but there's no freezer in this model so I don't know how it could be the defrost timer.
Dec 03, 2007 | U-Line 75R Refrigerator
U-Line 75R Refrigerator Logo
480 people viewed this question
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
