Question about Nokia 5300 Grey Cellular Phone
Nokia mobile 5300 is not support any sim card
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 139 Answers
Sir it's sim slot won't be working then. You can go and chck it through the relivant company. :)
Posted on Dec 13, 2009
  • 4 Answers
SOURCE: need code
Is the Nokia 5300 even compatible with a Cingular SIM card?? I want that phone, but I don't know if my family is staying with Cingular or moving to T-Mobile..
Posted on Nov 12, 2007
SOURCE: Nokia 5300 xpress music mobile phone won't ring
did you going to settings and then to tones?
Posted on Jan 20, 2008
Jus ask me
  • 120 Answers
SOURCE: 5300 master reset code
this will need the attention of the nokia care persons at nokia show rooms.
only they can help you with this
Posted on Aug 01, 2008
livingsta
  • 76 Answers
SOURCE: i have bpl sim card,i want to know setting for using wap internet on my mobile 5300
Hi i was reading regarding WAP settings for BPL mobile...I have copied and pasted what i saw from different forums...see if it is of any help
you can manually conigure GPRS in your mobile phones.
BPL_WAP
homepage http://wap.mizone.bplmobile.om
Session mode permanent
connection security off
data bearer gprs
gprs access point mizone
IP address 10.0.0.10
authentication type normal
login type automatic
BPL_MMS
data bearer gprs
For those who are interested in using GPRS facility provided by BPL Mobile (Mumbai only) here are the brief n settings required for it. You can also use this for surfing Internet through you PC provided your PC is connected to your mobile using Data Cable or preferably BlueTooth.
Go to the main menu and open “Settings”
Select “Configuration” and then “Personal Configuration Settings”. Create a new configuration settings by selecting “Add New” from “Options”
The account fields should be filled as below:
Account Settings Account Name : bplweb
HomePage : http://wap.mizone.bplmobile.com
User Name : Your mobile number
Password : bplmmsc
Use Preferred access point : No
Access point settings : As given below
Access point settings Proxy : Enabled
Proxy Address : 10.0.0.10
Proxy port : 9401
Data bearer : Packet data
Bearer settings : As given below
Bearer settings Packet data access point : mizone
network type : IPv4
Authentication type : Normal
Password : bplmmsc
Now once you have done that get back to “Personal Configuration Settings” select the new account “Bplweb” that you have just created and go to “Options” and click on “Activate”
Go back to the main menu and open “Settings”
Select “Connectivity” and then “Packet Data”
Set the “Packet data connection” to “When needed” and then click on “Packet Data Settings” then “Edit active access point” and then set “Packet Data Access Point” to bplgprs.com
These instructions are according to the Nokia sets 3110c, 6085 and should not differ much for other sets and brands and in case of which you can always go to the customer care as did.
BPL WAP SETTINGS FOR MOBILE PHONES
Connection name:- BPL WAP
data bearer: packet data
Access point name: mizone
User name: 919821099800
Prompt password: no
Password: bplmssc
Authentication: normal
Homepage: http://wap.mizone.bplmobile.com/
ADVANCED SETTINGS
network type: IPv4
Phone IP address: automatic
DNS address: automatic
Proxy server address : 10.0.0.10
Proxy port address : 9401
Hope this helps !!!
Posted on Apr 17, 2009
SOURCE: I need restriction code to unlock my nokia 5300 music express cel
If you purchased your phone via T-Mobile and are still a T-Mobile customer, contact them either via phone or email and they will send you your unlock code. If you are no longer a T-Mobile customer, there are a number of Web sites which will send you an unlock code but you will need to pay for this service. But please be aware, normally unlock codes work well but you always run the risk of what is called "bricking" the phone. Which means if the wrong code is entered or entered wrong, the phone becomes useless, hence the term becoming like a "brick".
Posted on May 18, 2009
Restriction code
Are you sure that your Nokia 5300 Xpress Music is completely unlocked from network restriction? If you have unlocked it, you can definitely use any other GSM SIM card with it. If you are not able to access any SIM card with it, it seems to be you have made some mistake in unlocking. The safest and easiest way to unlock a Nokia 5300 Xpress Music is using unlock code. You can get the accurate unlock code for a Nokia 5300 Xpress Music from OnlineGSMUnlock.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 5300 XPRESSMUSIC without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5300 XPRESSMUSIC.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5300 XPRESSMUSIC would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5300 XPRESSMUSIC mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5300 XPRESSMUSIC
Aug 30, 2014 | Nokia 5300 XpressMusic
How to flash nokia 5300
GO TO STORE........
Oct 01, 2011 | Cell Phones
Plz send me unlock code
http://www.unlock-free.com/nokia-master/
Takes care of most nokia phones. It's a free solution.Please follow site instructions.
Please rate the solution.
Cheers
Jan 09, 2010 | Nokia 5310 Cellular Phone
Asking for restriction code Type: RM-147 Nokia 5300
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone.
Nov 23, 2009 | Nokia 5300 Grey Cellular Phone
My nokia 5300 handset not working in all sim card
this phone might have been made only to detect the airtel sim cards as the phone in question might have been made only for the air tel company
in collaboration with nokia .
so there might be no code for it to allow all the sim cards .
imagine it like the cdma phone distributed by reliance communications
Jan 12, 2009 | Nokia 5300 Grey Cellular Phone
Nokia 5300 t mobile
when i turn on my phone it says pin blocked enter puk code
Jan 08, 2009 | Nokia 5300 Grey Cellular Phone
Free unlock codes for nokia 5300
I: forget my security code for Nokia 5300 can u pls help me out.
May 11, 2008 | Cell Phones
Nokia 5300 hang
Type in:
*#06#
for checking the IMEI (International Mobile Equipment Identity)
Try these codes one first, if it does work try 2 then 3
#pw+946423646114023+1#
#pw+938651127328995+2#
#pw+211777409857954+3#
Other wise most shops will do it for you.
or maybe not in the Philippines.
Dec 27, 2007 | Sony Ericsson K800i Cellular Phone
NOKIA 5300
sir there still the one to service your phone i think they have a software to read the security code of your phone and same as your sim-card, cuz' every sim-card has a digit number, its a verification for PUK code and they have an access to that.
peace!
Nov 27, 2007 | Nokia 5300 Grey Cellular Phone
Need code
Nov 03, 2007 | Nokia 5300 Grey Cellular Phone
Nokia 5300 Grey Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Laxman Bisht
Laxman Bisht
