Question about IBM Office Equipment & Supplies
I have a couple of IBM Selectric II Typewriters and over the last few months both just quit as if they are getting no power. One started working again but then quit again..any ideas on how to fix. Also had a Selectric II that kept turning the correction tape while I typed any ideas Thanks
  • IBM Master
  • 3,594 Answers
Most selectrics at this time are suffering from many gummy parts.
All of these problems are probably repairable with a good chemical cleaning and lube.
DickyO
Posted on Dec 14, 2009
Anyone got a possible answer for why my IBM correcting Selectric II won't come on?
If you know how to remove the upper cover there are a few things you can check. turn it on if the motor is trying to turn it may be gummy motor bearings lube them If it dosen't try the off on switch may be gummy. almost anything you will need a tech.
DickyO
Oct 08, 2014 | IBM Correcting Selectric II
IBM correcting selectric won't type
Michele, this machine perhaps sitting unused for few years. SO, It needs a thorough cleaning - I mean Clean it before you power up. What about the ribbon condition. Good luck and happy back to yester years.
Apr 08, 2014 | IBM Office Equipment & Supplies
Recommendation for IBM Repair Company
I Googled Typewriter repair Washington DC and got 4. I have no idea what they charge.
DickyO
Apr 02, 2014 | IBM Correcting Selectric II
Broken metal wire in ibm selectric ii
You have either a broken tilt tape or rotate tape. One controls the tilting of the element (ball) and the other controls the rotation of it. If either one is broken, you will need a qualified technician to replace it and make any adjustment necessary so it doesn't break again.
Oct 17, 2013 | IBM Correcting Selectric II
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
DickyO
Jul 31, 2013 | IBM Correcting Selectric II
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
IBM Selectric II
Yes. From not being used in so long It needs a chemical cleaning or washout and lubrication. It may need a part or two also. Everything is gummed up. I have been repairing selectrics for 35 years. Lawrence
Apr 20, 2008 | Lexmark Wheelwriter 15 Series II...
235 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
