Question about Toshiba 50H81 50" Rear Projection Television
My color is off on my whole tv i have a 52''projection toshiba cinema series the old big style and was wondering how to adjust the colors so they match up
    Scholar:
  • 55 Answers
Read Each Step Completely - Make Sure 3 Color Guns Are Off And Cool -
1. Remove Rear Dust Cover 2. Remove the Front Speaker Cover May be Held In By Plastic Pins and or Anchors on the Bottom Note" - Remove The Plastic Cover Just Above Speaker Cover Maybe 2 Piece. Remove The Screws Holding Top Of Speaker Cover. Then Pull Toward You the Bottom Maybe Anchored So Lift Up. 4.Once Speaker Cover Removed, May Have Screws Just Below Center Plastic Cover Remove Them, Now Remove Center Cover Between Speakers -NOTE" Do Not Touch, Move Any Color Convergence KNOBS" - Lift Front Screen UP - Towards Roof - It Has 3 Flex Grab Anchors On Top And 2 Pins One On Each Side Of TV Frame. - NOTE" Lay Screen On Floor It Is Plexi Glass So It Will Brake If Bent Or Drop Hammer On. NOTE"- May Have To Remove plastic Cover Frame positioned Around Front Screen And Then Remove Screws. 5. I Use Windex Glass Cleaner And Either Cotton Balls Or White Tube Sock On Color Gun Lens Covers And Clean Mirror Like The One In Bath Room. 6. Take White Sheet Or Bead Spread And Anchor On top Of TV With Weights, Stretch Around Each Side Of TV Use Chairs To Anchor On Each Side Of TV. Place Dust Cover Or Heavy Card Board Where Plexi Glass Was Positioned. 7. Turn On TV - go To Rear and Now You Can Adjust Colors Brightness And Low Light - High Light - Horizontal - Ect....While Looking at Picture. 8. Install In REVERSE - Order Just Wipe Color Guns Lens Last. Note" - If you have Wet/Dry Vac or Fan Or Blow Dryer Take A 2 - to - 3 Inch Paint Brush And While Brushing Circuit Boards Any Dust For That Matter Blow Dust Off And Out Even Brush Speaker Cover"...ECT...Do This Before Any Cleaning 9. Just A Thought If You Ever Want to Change Color Gun Cooling Oil - Wrap All Circuit Boards With plastic Bags And then I use Bath Towol And Paper Towols To Catch As Much Spill As I Can And Then Spray With Windex To Make Dry While Blowing Air Onto Spill - Also I have Found Clear Mineral Oil Like Johnson Baby Oil To Work As Well If Not Better Then Glycol Oil. I Get For $2.50 For 20 Oz Bottle.
Posted on Dec 29, 2009
    Problem Solver:
  • 3 Answers
Sounds like what was wrong with mine! Take the remote and hit menu, then scroll to the Video Adjust button, then adjust the "convergence" or the color tone, brightness, contrast etc. My repair man did this and it helped get the picture much more life-like. He said over time they get out of line and just need a few adjustments. He just charged the $50 house call. Good luck, hope you can fix it.
Posted on Dec 11, 2009
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
I have a 55 in Toshiba Cinema Series HD the colors are out of alignment so I have three pictures stacked behind each other. Is there an adjustment or repiar
I have a Cinama Series HD Toshiba and it has a Problem with the picture theres red letters behind the white , it like the colors are stretched, theres red eye above the real eyes and same with the teeth area, what could be the problem?
Nov 09, 2010 | Toshiba TN61X81 61" Rear Projection...
My Toshiba cinema series HD separates the red & blue color.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
Color convergence issue.
Yes,U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairworld.com to buy a convergence to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 27, 2010 | Toshiba 55H70 55" Rear Projection...
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
230 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
