Question about HP Color LaserJet 3500 Printer
Density sensor out of range
Hp color laserjet 3550 event log showing "density sensor out of range"
  • 1 more comment
  • jaimon Jan 20, 2008
    what happened?
    is it fuser problem
  • Soulvisitor
    Soulvisitor May 11, 2010
    not fuser, never seen it before myself, but I be inclined to think cartridges were the issue, are they gen hp? How old is transfer belt?
  • 22 Answers
CLEAN THE DENSITY SENSORS POINTING AT THE TOP OF THE TRANSFER BELT. A COLD RESET CAN HELP TOO
Posted on Jun 24, 2008
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
Hp color laserjet 3550 59.99 printer error
This error shows
An error occurred in the secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
3. Faulty feed motor.
Action: Replace the feed motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
Nov 09, 2009 | HP Color LaserJet 3500 Printer
The density sensor is located in what is called the Colour Registration Detection Assy. When you open the front door where the ETB belt is, the assembly sits were the door closes at the top on the printer side.
It can get toner on it, so check it and give it a clean. But do not touch it with your fingers.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
Hp 3500 faint printing and colours wrong
Rich,
Well, first off, are you using OEM or compatible cartridges? Compatibles are OK, just as long as they weren't rebuilt just by refilling. Secondly, you may want to check in the "Print Quailty" menu; here you will find info on increasing and decreasing the print density. Do you observe light printing over the entire page or just ceratin areas? How about certain colors? More to follow...............
Aug 12, 2008 | HP Color LaserJet 3500 Printer
HP 3550color laser jet printer
Could be a couple of differnt things and the complete run down would be extensive. Here's a link to the complete service manual in PDF for free. You can look it up and even repair it once you download the manual. Hope this helps: :)
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%203500-3550-3700.pdf
May 27, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Paper jam
If you have pulled out paper that was stuck before you may have flipped a sensor flag out of position. I have found in the past small pieces of paper left under the plate at the very bottom of the toner catridges where the paper comes in.
Jan 04, 2008 | HP Color Laserjet 3550 Printer
HP Color LaserJet 3500 Printer Logo
1,121 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
