Question about Car Audio & Video
Amp i set in my car on break and it worked fine i get in a couple hours laterr to go home and my subs and amp still work there just no where near as loud what would cause this ?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
See if your deck is muted.
Posted on Jan 20, 2008
6ya staff
SOURCE:
JL Amp isn't powering subs and speakers
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
My subs don't bump to the beat, they just go THUMP THUMP THUMP...
It sounds like you need to ask for pro help mate, mybe the amp just needs setting properly, Is the amp on bypass for bass, or does the amp run the complete system
Jun 13, 2009 | Cadence TXA 750D High Power Mono Amplifier...
Subwoofer makes a loud bass machine gun noise when powered up
Well, I have the same problem and I would think it has something to do with the RCA-connections. If I power up my head unit while I have my main fuse for the amp's removed and then replace the fuse as the head unit is already playing music (thus putting out a current through the RCA-connections) it works just fine. But if I just power up my stereo with the fuse in, my subs go all crazy. I guess it has something to do with disruptions in the rca cable. Maybe they are drawn too close to some power cables or speaker cables? Good luck!
Feb 12, 2009 | Alpine IDA-X300 Car CD/ MP3 Player
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amp staying on but cutting out?
Hello Willb2396,
Actually you answered your own question in your paragraph. I draw your attention to your statement of:
"It will work for as long as I'm driving I will park my car, and when I turn it back on every thing will be working just fine and, then a couple minutes later, amp cuts out and won't hit for a couple hours or a couple days.... I have checked the sub multiple times and I don't see it being the sub or the amp"
You are correct it is neither the Sub nor the Amp. The problem is either your voltage regulator or your alternator. one and or the other is going bad.
Here is some advice check your ground wires, the buy a dual alternator kit, it contains the parts you will need to add an additional alternator to your car. This will provide the power you need.
I hope this helps,
Thank you,
Shuttle83
Nov 10, 2008 | Alpine MRP-M650 Car Audio Amplifier
Cant figure out my car audio problems!!!!!
There are a couple of tests you can perform. I'd first recommend checking the shield ground. You'll need an ohm meter. The details can be found on the following page.
RCA shield ground test
You can also test the output with the multimeter. Set the multimeter to AC volts. If it's not an auto-ranging meter, set it to a voltage range of ~2v AC. Disconnect the RCA cables from the head unit. Touch one meter probe to the outer ring of the head unit's RCA jack. Touch the other probe to the metal contact in the center of the RCA jack. With the head unit near full volume and a clean signal source, you should read at least one volt on musical peaks. If you have a bass disc or a test tone disc (~60hz sine wave), use those.
May 04, 2008 | MTX Thunder 8302 Car Audio Amplifier
SubWoofer
Sounds like your original and this sub have bad amps. The amp for the sub is not the same as the amp for the other speakers. The old unit has a dead amp and this new one is on the way out. (Pulling too much current on high bass)
Mar 30, 2007 | JVC TH-M505 System
Car Audio & Video Logo
211 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
