Question about Compaq Presario 700 470024-192 Notebook
Showing message 'failed replace hard-disk - 1 warranty id code 10008
  • 3,940 Answers
Pretty straight up, message indicates a failure of the hard drive and time to get a new hard drive.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822116026
Posted on Dec 11, 2009
4 Suggested Answers
the_fire
  • 432 Answers
SOURCE: Failed Replace hard disk 1 warranty id code
As the error message states you need to replace the hard drive as the hard drive is most likely dead ie not working / broken.
Posted on Apr 16, 2009
  • 72 Answers
SOURCE: Hi!My laptop (HP G7000)can not
Your hard disk has indeed failed, this is not an indication of a spyware problem. Your best bet, if the laptop is under warranty, is to contact HP for a replacement hard drive.
If, however, your are out of warranty or would prefer to do it yourself, it appears your laptop has a 2.5" SATA hard drive. You don't need a huge one, your failed hard drive was probably between 80-160GB. Do not get a hard drive with a PATA/IDE interface, or a 3.5" hard drive, as these will neither work nor fit in your computer.
There are several screws on the bottom of your laptop. You will not likely need to remove the entire laptop case, and many times the bottom of the laptop is labeled with icons or a description of the component beneath the panel in question. When you replace the hard drive, pay attention to the orientation of the old hard drive, as well as where any different size screws were placed.
Finally, you will need to restore your computer with a set of disks. As you will be replacing your hard drive, any restore partition that was previously on your computer will have been lost.
Please let me know if you have any other questions related to this issue. Thanks!
Posted on Aug 11, 2010
ViscamTech
  • 528 Answers
SOURCE: primary hardself test shows failed hard disk 1
Your hard disk has a damaged area. Apparently this is close to the end of the storage area. Since there are no software in that area, you will have no problem. (Because the OS not trying to access any files in the damaged area).
Try not to fill the hard disk more than 80%. If files are written in the damaged area, you will experience problems with your laptop.
Posted on Sep 11, 2011
Testimonial: "that explains alot. Thank you for such a quick response"
Primary hardself test shows failed hard disk 1 (warranty id-error code 10008). it runs until it's 95% complete. however i have absolutely no problems with my computer/laptop. very confusing.
Sep 11, 2011 | HP Compaq Presario C700T
I am having HP pav DV6663 laptop . Currently i am facingthe problem #10008 - Replace the hard disk message while i tried dignostic test for harddrive. Is my hard disk is crshed, and now unusable? whats...
This message is generated when the hard disk has failed completely, at a hardware level = it busted.
You must replace the disk, no way around that - a new better/bigger one will cost you about $40
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5013592&CatId=1277
Apr 24, 2011 | Compaq Presario Notebook
Erroor code 10008
According to Compaq tech support. That error code of 10008 indicates the hard drive has failed and should be replaced. I would recommend contacting HP/Compaq and finding out your warranty status. If it is still covered under warranty, they can replace the drive with a new one. You will need to contact them to find that out.
Apr 13, 2011 | Compaq Presario Notebook
Hi!My laptop (HP G7000)can not boot, currently when I diagnose the hard disk using "BIOS Hard Disk Self Long test" I get this message"Failed - replace Hard Disk 1 (warranty ID - error code 10008". What...
Aug 11, 2010 | Computers & Internet
The message on the screen says primary Hard Disk
Every hard drive has in it a hardware test system - the one from yours has just announced you that your disk has died. Replace it and reinstall Windows.
Jul 22, 2010 | Computers & Internet
Laptop will not boot up warranty id error code 10008
Hello my friend.This is means that your hard disk is corrupted,has bad sectors.If you can boot at all to run the disk diagnostic program then your hard drive is dead and you must replace it.Is not difficult to replace it.Usually if you turn your computer you will see a small cover with screws,there is your disk and you can take it off and go to a shop and buy another one similar.Usually is 2.5inches and you choose the capacity you want.
Feb 08, 2010 | Compaq Presario Notebook
Asi gave mine laptop compaq c700 pc notebook to hp service centre for check up. they told me that there is a hard disk problem .so the problem was "HDD test fail & check with another HDD.& all...
Only Hp knows what that means in their diags. Get it shipped back and take it to a Locally owned PC shop and have them take a look at it. It is possible that you have just enough file fragmentation and file structure corruption that it is fail diags. Why did you take it in to be looked at anyways?
Sep 11, 2009 | Compaq Presario 700 470024-192 Notebook
Error message: Failed- Replace Hard Disk 1 (Warrany ID error code 10008) what does this mean I have a compaq Presario A900
It means that Hard Disk 1, which is either the first or second harddisk in the laptop, has failed. First open the BIOS on your latop. Before windows startup there should be a Compaq logo on screen. There also is some text saying which key to press to access BIOS. In BIOS, try opening some menus and look for a menu that shows your disk drive. In the same menu should be your harddisk. If it is there, go to A. If not, go to B. A: The disk is not broken, it just made a write error that destroyed WIndows. Insert the disk with your operating system on it into the laptop, and reinstall it. Your data is gone, but the laptop will work. If reinstalling the OS gives errors, and is unable to complete, go to B. B: Your harddisk is broken. There is no way to fix it, and you will need a new one. Contact Compaq if your warranty is still valid, and if not, take it to the nearest computer shop and ask for a new harddisk. If you have any more questions or trouble just post back here. I hope this helps, Yannick
Jun 07, 2009 | Compaq Presario Notebook
Failed Replace hard disk 1 warranty id code 10008
Apr 16, 2009 | Compaq Presario M2000 Notebook
A disk read error occurred press Ctrl Alt Del to restart...But when I do this it wont restart...I did a start up check and its telling me the following...FAILED,REPLACE HARD DISC 1, WARRANTY ID, ERROR...
The hard disk drive has failed and needs replacement. If this system is under warranty, contact HP
If not, then you can buy a replacement HDD from retailers like NewEgg.COM
I checked the HP spare parts page, their prices are quite high. Here is an example of a good value:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148073
Sep 01, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
1,347 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
