Question about Acer Aspire 4520 Notebook PC
I have a acer aspire 4520 notebook computer and
I have a acer aspire 4520 notebook computer and it was working fine last night but today it won't even power up. When I press the power key it breifly lights up as well as the 3 lights on the left indicating the hard drive, key lock and other lock idicator briefly light up also then blacks out, the screen doesn't even attempt to power up. Any help in fixin this would be greatly appreciated
  • 26 Answers
Okay, Here's the deal..... I recently had the same problems with my friends' Acer Extensa laptop and here's what I did to fix it. I narrowed the issue down to two culprits 1. Overheating, 2. Defective Motherboard. I have fixed the problem but I takes time, patience and some technical ability which may not be available to some. :( (Swapping out the motherboard MAY fix the problem but if the defect is in the manufacturing process then the problems could return). Here's how I fixed it... While in the process of disassembly I noticed a small electrolytic capacitor that had seemingly broken off and had become wedged between the frame (very lucky! this gave me the clue I was looking for!). This made me think that it had broken off the motherboard. I proceeded to disassemble the laptop and found the location of the missing capacitor (there are two located right next to each other on the board) and was able to re solder the capacitor back onto the motherboard (could it be a manufacturing processing defect thats causing these to break loose? ). Mine was broken off due to what looked like bad solder joints. Your capacitors could still be attached but have weak solder connections. Also while i had access to the motherboard, I used the opportunity to clean and re apply the heat sink compound to the CPU and thoroughly clean the fan vents. I then reassembled the laptop and EVERYTHING has been running fine now for the last 3 days. Total time was about 4hrs and it cost NOTHING to repair. GOOD LUCK :)
Posted on Mar 14, 2010
My acer aspire 4520 wont start. Plz help me
Hi, Could you please give the details. Is the Notebook not booting up or not turning on ?Please press the power button and check the lights in ur Notebook, whether the power is generating. Please repeat this step when the charger is connected.Also, if the lights are on, then try press "Delete" key couple of times.
Please try out these and let me know the result.
Thanks & Regards,
Apr 26, 2012 | Acer Aspire 4520-5582 Notebook
My sound on my acer aspire 5516 works fine until i put in a dvd then the sound will not work how do i turn it on ?
Double click the "speaker icon" on the right bottom bar to open the
volume control menu.
Check be sure that the check box "mute all" on the bottom of volume control
is not checked.
On an "Acer Notebook" try to press following keys combination: FN+F8
FN+ F8 : turn on / of speaker.
FN + > to increase the volume.
Good look
Feb 19, 2011 | Acer Aspire 4520-5582 Notebook
I cant turn on my wireless capability what button do i press
Try pressing the FN key and the F5 key at the same time.
Let me know if that works.
Aug 17, 2010 | Acer Aspire 4520-5582 Notebook
I had the Blue Screen Of Death (BSOD)on Wednesday after installing the Microsoft updates Tuesday night. Now what?
First thing i would try,
right after your computer finishes post, start pressing the F8 key.
This should take you to the windows startup menu.
look for the option that says    restore last know good configuration.
highlight that selection using the arrow keys and then press enter.
if that doesnt allow you to boot, at this point a system rollback to a previous restore point would correct this problem.
i wont go into the procedure now, but if you need further help just comment in here.
hope this helps
Feb 16, 2010 | Acer Aspire 4520 Notebook PC
Hello all. I am currently the owner of an Acer Aspire 4520. Lately, I have noticed that it is not coming on as it should. When I press the power button, it turns on for a few seconds, and then turns off....
I'm having tha same issue with my 4520. I found the service manual at this link. http://printer1.blogspot.com/2008/01/acer-aspire-4520-service-manual.html
It has a good troubleshooting and dis-assembly procedure. Unfortunately, mine loks like a bad motherboard. If you find a solution let me know.
Jan 06, 2010 | Acer Aspire 4520-5582 Notebook
How to download empowering technology drivers for aspire 4520
do a google surf for the drivers using the key words
"drivers for aspire 4520 download "
i am sure you would find your drivers...
Jan 12, 2009 | Acer Aspire 4520-5582 Notebook
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
Aug 26, 2007 | Acer Aspire 5100-5033 Notebook
Open Questions:
Acer Aspire 4520 Notebook PC Logo
267 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
