Question about Dell Computers & Internet
I get the error code 2000-0146 only when i run the f12 diagnostic
I get the error code 2000-0146 only when i run the diagnostics (F12). other wise my laptop boots just fine and hard drive passes all the dell pc check-up such as funnel seek test,hard drive random seek test,smart status test and displays no issues.What do I conclude ?
  • 3,940 Answers
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
What is FCCID:CC3K1496 For a dell laptop by Microsoft
The dells i use to work on had built in diagnostics, you could try pressing F12 to see if yours has this its called ePSA diagnostic tool, you press F12 when the dell splash screen appears then use arrow to scroll down to highlight diagnostics. It takes about 4 minutes to run. Hope it helps.
Dec 15, 2014 | Dell Computers & Internet
0xoooooe9
Does the computer boot into Windows? If not it appears there is an issue with your hard drive. When you turn on the machine, try to get into the diagnostics mode of the computer (F12) and then select BIOS Diagnostics. From there run the tests to see if the hard drive is bad. From there you might have to get a new one.
Aug 17, 2014 | Dell Inspiron 531s Desktop Computer
Dell error code 0326
Error Code 0326 means LCD inverter error, unable to turn lamp ON/OFF.
  • Update to the latest BIOS.
  • Turn off your computer and reconnect your LCD cable.
  • Repeat the diagnostics by turning your laptop on and tapping F12 and selecting diagnostics
  • if you still get that error then it could be these parts LCD cable+LCD needs replaced
Jun 16, 2014 | Dell Inspiron 1525 Notebook
Internal hdd hard error
Using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
Nov 19, 2013 | Dell Latitude D610 Laptop Computer -...
4400:011A error
Yes it looks like a Failing Hard Drive. I suggest you backup all your data. Press the F12 key at the Dell Logo, select diagnostics and run an extended diagnostics on your hard drive.
Oct 18, 2013 | Computers & Internet
F12 error code
Also here is a list of He2 error codes http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
I think the error code you are actually getting maybe an F21 due to there is no listing for F12. use this kink to put the unit into diagnostics and run the diagnostic menu which will give you your exact error code as well. I await your reply
Thank you
Rick
Dec 02, 2011 | Kenmore HE2 Plus Front Load Washer
I have a dell inspiron E1405 laptop. when i am not using it for half an hour after opening it it is going into the following error: error code: 0148 message error code: 2000-0148 message unit:...
Go to
http://support.dell.com/support/0148
For further support as you have a hard drive error.
Hope this helps.
How to run PSA Diagnostics
Article Summary: Instructions on how to run the PSA Diagnostics, and an Error Code list with possible solutions. Table of Contents:
  1. Start the PSA Diagnostics
  2. Error Code List
Step 1: Start the PSA Diagnostics
  1. Restart the system.
  2. At the Dell logo screen, press <F12>.
  3. new_note.jpg Note: Some systems do not have an F12 key, to access the boot options you have to press the <0> (zero) key at the Dell logo screen.
  4. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
  5. Write down any error codes listed.
  6. Use the list provided in the next section to see what the error code means.
Feb 16, 2011 | Computers & Internet
My dell laptop won't let me go to the login screen how can I fix it?
Initiate diagnostics first to isolate the problem. go to boot menu by pressing F12 during the Dell Logo Screen then choose diagnostics. If theres no error code from the process that means you need to reinstall OS
Sep 29, 2010 | Computers & Internet
When i open my computer, its running but after a few minutes its automatically turn off
There could be a hardware problem on the computer if it just stays for a couple of minutes and automatically turns off. I would suggest to run a Diagnostic test first
1. Turn on computer
2. Tap F12 on the dell logo screen
3. Select Diagnostic Test
4. Finish the test (approximately 10-15min.)
5. If there are error codes, it means there is a hardware problem
Provide me the error codes, and i will tell you which causes the problem.
Dec 15, 2009 | Dell Latitude D800 Notebook
Unmountable_Boot_volume\Upon start up...this is
run firs the diagnostics either from the boot menu on F12 utility partition or using the dell utility disc.
when you power on laptop then you tap on F12 upon seeing dell logo it will bring you to the boot menu. select utility partition or dell diagnostics if you have one. then run the test for system and custom test for the hard drive. if you get error code replace hard drive.
Dec 09, 2009 | Dell Latitude D800 Notebook
Computers & Internet Logo
2,787 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
