Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
The T.V. just shuts off every once in a while without the settings of energy saver on. how do I get this to stop?
  • Eric Arsenault Dec 11, 2009
    Thanx this was very helpfull!
  • 10,515 Answers
Without testing the circuitry there is no way to be positive why the TV is shutting down. This model TV is know for having problems with it's power supply. This could be the reason for the picture shutting down
First push the menu button with the set s remote and check if that could help you.This is a very common problem with LCD and also DLP within the power supply the capacitors.Start to fail and the way you can tell is to check them visually for swelling or expanding of the top.It will be easy to see the bad caps will not be as flat on the top as the good ones, this is the problem.Exchange them and you will be ok, Well good luck friend. And if it doesn't work make sure the power supply is sending 24v to the inverters when you turn the set on your meter should climb but won't reach 24v because unit will shut down and if so we ruled out the inverters or backlight I seen this problem also caused by the signal board it has a power on command missing and it looks like the power supply is bad but actually it's the signal board, it may be labeled on the board a active high or low 5v which sends the command to the power supply.Capacitor pictures inverter pictures... cold spray can be used if your set works for awhile then shuts down.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 11, 2009
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
I set ac at energy saver 71 degrees. The ac goes
yeah you have to be carfull the only thing that does is shut the inside fan off it does not mean anything. it is a selling thing
Aug 04, 2009 | Heating & Cooling
I want to adjust/disable the energy saver on a Panafax 9000
Press Function 74 set scroll down to ENERGY SAVER make it INVALID set stop
May 12, 2009 | Panasonic PanaFax UF-8000 Laser Fax
OFF Button?
Sorry, there is no On/Off switch on that printer. When plugged in it will automatically go to Standby.
The Energy Saver can be set anywhere from 3 to 30 minutes.
The only way you can remove all power to it is to pull the plug from the wall outlet.
PLease do not "shoot the messenger" here.
You asked, and this is the answer, so I would appreciate a Fixya rating.
(Is it really a problem using the Energy Saver?)
Jan 17, 2009 | Canon imageCLASS MF5730 All-In-One Laser...
I can't get my camera to work with my messenger program, can you help (AOL, Yahoo, MSN)? I have a mac book pro, and i try to use the built in camera, and it shuts off ever 2 min, or so, and i have to...
Have you gone into System Preferences (click on Apple icon, top left of screen) and changed the Energy Saver settings? If the Energy Saver settings are set too low, your Mac will shut down.
Jul 13, 2008 | Apple MacBook Pro Notebook
Wake up from energy saver mode
the menu where you set the time once you've scrolled though all the time options will give the option of disabling it.
Jul 10, 2008 | IBM 6400 Matrix Printer
Energy Saver
On most copiers, you can't totally disable it... it's all part of that "energy star" rating thing. It's annoying, i know.
Jan 09, 2008 | Toshiba 2060 Copier
Lg 10000 btu ac wall unit
if you remove the front cover you should see a little sensor with a wire. you need to make sure it has not fallen off its bracket or came off form the evaporator. if it looks to be ok and mounted correctly, you may have a bad sensor and it is not able to tell the temp and not shut the unit down. also to on very hot and humid days even though you have it set to energy saver it senses it still needs to run. If you turn the thermostat up when its on the energy saver will it shut off? and if you do the same on the regular setting will the comressor shut off and the fan stay running? Let me know and I can go from there. Thanks
Aug 05, 2007 | LG Electronic Window Air Conditioner
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
