Question about Linksys Wireless-G WRT54G Router
Cable went out, eventually fixed and confimed internet connection via ethernet line. now router doesn't work
  • Brandon
    Brandon May 11, 2010
    Whats your ISP?
    Problem Solver:
  • 13 Answers
Try resetting the router. There is a reset button on the back panel. You will need a pen tip or toothpick to press this button. Once you reset, then configure the router as if new.
Posted on Dec 11, 2009
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
Apr 28, 2012 | Linksys WRT120N Router
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
Linksys E3000 Wireless Connectivity Problems the router is excessively hot too. Can connect with ethernet cables I have cable mode and the cable company sees my lan card I can get internet connected via...
That excessive hot temperature of your router is not a good sign, it means that something is wrong with it and the problem is hardware base and in just a few more days or weeks the router will eventually stop working even when using ethernet cable.
The best thing to do here if the router is still new and under warranty is to have it replace from store or from where you purchased it.
Mar 04, 2011 | Linksys E3000 Wireless Router
What is theam.if we apply theam the wole appreance will change or only on desktop
How Can One Cable Modem Work With Two Wireless Routers? By Terry Stockdale Leave a Comment In How to Fry a Wireless Router or Two, I wrote about my brother's experience frying a pair of wireless modems in a lightning storm. Last week, I talked about what had happened, why it happened, and what he could do to prevent the problem in the future (this was the third set of routers, plus he lost a computer motherboard in that storm).
This week, we'll look at his network layout, and why he could not get the network to set up properly.
To summarize the situation, he has an office an a shop, with computers on his network in both locations. Some connect via wired connections (Ethernet), while others use wireless connections. His Internet cable comes into the office first.
In the past, he first used Linksys wireless routers. Then DLinks. This time, he chose Belkin wireless routers.
The incoming cable (standard cable-company RG6 coaxial cable) connects to the cable modem.
Then, the cable modem connects to the WAN (wide area network "Internet") connection on the router.
The local wired ports on the router provide connections for two wired computers. Notebooks connect via wireless connections. Finally, one wired connection on the router is used to connect an Ethernet cable that runs 250 feed to the office from the shop.
That cable was the lightning problem, as it runs outside in a conduit just a little bit underground. Effectively, he's got a 250 foot antenna looking for the electromagnetic pulse from a lightning strike. Most of us don't worry about that because our equipment is so well grounded in the house, plus the Ethernet cables we use are much shorter lines. Even if we have underground cable company lines running from their switch boxes to our houses, those lines are usually only exposed about 40 to 50 feet before they enter the dwellings.
Back to the situation. When he hooked up his replacement routers, the router at the shop immediately worked. Not so, on the router in the office. The Ethernet light and the Activity light just poounded away, blinking and blinking rapidly. But, nothing connecting to the router could get to the Internet.
If they connected a computer directly to the Ethernet cable in the office, without running it into the router first, it worked just fine. But, with the router in place, it didn't work.
The problem was the way he connected the two routers. The problem is that there is no Out Of The Box connection that will work reliably. At least one thing, usually two, has/have to be tweaked one way or another.
As one might guess, the easiest way to connect would be to connect one router's WAN connector to the cable modem, using Ethernet cable, and then use Ethernet cable to connect one of the Local Area Network (LAN) connectors on that router ot the WAN router on the other computer.
There is a problem with this setup, but it's easily solved. First, if you're using identical wireless routers, as he was, the wireless routers are both trying to use the same IP Address range and subnet mask for their local area networks.
That works fine for the first router, which is connected to cable modem. On the cable modem side, it gets an IP address on the Internet Service Provider's network - often an actual Internet address and not just a private network address. On the local area network, it assigns the IP address range specified in its setup menu. This often varies by manufacturer. In the case of Linksys, this is 192.168.1.x. In the case of the Belkin routers he bought, it was 192.168.2.x.
The problem occurs at the second router. On it's WAN side, it sees a 192.168.2.x network - but it's default setting tells it to give 192.168.2.x addresses on it's local area network side, too. In other words - it's confused. It doesn't know where to find the Internet because both networks are assigned the same addresses.
The solution was to disconnect the second router's WAN/Internet cable, connect to it via a wired computer, and tell the second router to use a different IP address range. We chose 192.168.3.x.
We hooked up the Ethernet cable to the Internet/WAN side of the router again. The router started working fine, normal light blinks for activity, no more confusion. The computers could get to the Internet just fine.
Problem solved.
That solved the Internet connection problem. However, no computers in the office would be able to share files or printers with the shop, nor would computers in the shop be able to share with the office. That was both acceptable and intended, in this case.
It could be done; however, that would require a different configuration on the routers and connections.
Jan 05, 2011 | Computers & Internet
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
Red Internet Light
Check your username and password from the subscriber
Feb 11, 2009 | Linksys (WRT54GC) Router
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Pc works via ethernet cable but wireless laptop cannot see the network
I think you have lost your PPPOE internet connection. Reestablish the connection. If this is not the problem, click your wireless connection on the taskbar and search for your wireless device and reconnect. BPCS
Dec 29, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54G Router Logo
22 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
