Question about Canon CanoScan 8400F Film Scanner
I was using my Canon 5200F for a few years with no problem. However I deleted this hardware/software by mistake and instal it again from original CD. From that moment I am getting message "unable to select twain source." When I open Canoscan toolbox settings and click select scanner the box is blank. I also tried restor my windows XP for few days earlier however it did not work. What to do?
  • Canon Master
  • 4,924 Answers
If the printer works ok ...go to the add new software ..and let it search to see if it finds the scanner as a separate device ...and let it install the driver from the disk ...do the same for the printer ...I suspect that you install the software for it without them drivers and the software to not find the devices..
so ...plug it ...and go to the add new software ...choose already added ..and see what are the results ...
also go to the device manager by right click on my computer ..properties ..hardware ..device manager ...if you can not locate the printer and the scanner in a normal state there are not seen ...if they are with a yellow mark ..they are seen ..but not installed proper..just update driver by right click....
there is a posibility that you upgraded teh software ..and the drivers are not compatible from the disk anymore....you should look fot the right drivers on the net or let me know if this is the case and I will try it for you ...
Posted on Dec 11, 2009
Re: Samsung CD-Rom SC-148C in Dell Dimension 2350 Cannot eject/open tray to CD-Rom - I have tried ejecting tray while re-booting from setup to see if its a software problem of some kind. I've...
  1. Turn off the power to the computer.
  2. Insert a steel rod (about 1.3 mm in diameter) into the emergency eject hole and push hard. (A stiff paper clip may be used).
  3. The disc tray is ejected a short distance. Pull it all the way open by hand. roadfox_2.jpg
Jun 01, 2011 | Samsung SC-148 CD-ROM Drive
Why can't I download my CANO SCAN set up CD-Rom on to my new Windows 7
The CD-ROM has the installers for older versions of Windows. The installation routines for the newer versions of Windows have changed considerably from those that were in use when the CD was written. You can get the drivers and Canon Toolbox software for the scanner from Canon: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25#DriversAndSoftware . Select Windows 7 in the dropdown menu. The software will work with any version of Windows 7.
The only exception is that the third-party software is not available for downloads. If you want to use the original CD software (assuming the disc is undamaged) and you have Windows 7 Pro or Ultimate, you can download and install Virtual PC and XP mode for a free XP virtual computer. Then install the scanner to the "XP computer" as you normally would. However, the virtual computer and the Win7 computer cannot both have the hardware installed simultaneously. So to share files, you may need to save them to external media (optical or hard drive). If you have one of the other versions of Windows 7, you can do the same thing with any virtual PC program and a licensed older version of Windows.
I hope this helps.
Feb 12, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I have a MP160 printer but I think I threw away the CD to install it by mistake. I have had the printer for a few years but recently had to clear my hard drive due to a virus. I need to reinstall the...
Since you don;t have the setup disc for this printer the only way you can install it is by downloading the printer driver/software from this link and then use that for installation of the printer to your computer, just click HERE and [proceed with the download.
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Laptop can't see install software on CD for Canon 5200F, so can not use the scanner. can I download the software/drivers?
Of course u can goto Canon website to download the driver for your system, here is the link: http://software.canon-europe.com/products/0010070.asp
Choose correctly the OS u use in your laptop.
YBC (/\)
Oct 14, 2009 | Canon CanoScan 4200F Flatbed Scanner
The first thing you need to do is to go into your Start Menu and select Printer and Faxes and delete any printers you don't use or have and to delete any instances of the 5100 and the MX310. Now go into your Start Menu again and select all programs and uninstall any programs linked to printers you don't have or use, and also the 5100 and the MX310. Now restart your computer. Once your computer is restarted use the CD that came with your printer to re-install the drivers and software. Plug your printer into your computer and Windows should install your printer. If you don't have the original CD I have included a link to the drivers and manuals online for you to download. I hope this solves your problem. Good luck!
Carol.
LINK: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
Apr 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon 5200F won't work under vista 32 Bit
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=120&modelid=10445#DownloadDetailAct
Click the Drivers and Downloads tab, Vista.
Pick the CanoScan toolbox and the driver.
Jan 06, 2009 | Canon CanoScan 4200F Flatbed Scanner
I lost the original software for my x73500 all in one printer scanner copier. I have tried to download the driver from www.lexmark.com. My operating system is windows me. Please tell me how to acquire...
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Drivers and software download areas for brands listed below, just click to gain access and then locate driver for your needs.
Brother Epson Sharp Canon Lexmark OKI Dell HP Kyocera Samsung Konica/Minolta Xerox Panasonic
PLEASE NOTE
When installing drivers/software it is generally a good practice to -
·                                 Delete old/previous installs
·                                 Leave printers USB cable disconnected from computer until newly installed software requests it to be connected.
Nov 29, 2008 | Lexmark Office Equipment & Supplies
Canon CanoScan 8400F Film Scanner Logo
87 people viewed this question
old marine
old marine
