Question about Sharp XR-10S DLP Projector
Projector turns on but does not illuminate bulb is good
  • fakhruddin jawadwala May 11, 2010
    WHEN POWERED LAMP DOES NOT ON COLOR WHEEL SPIN SOUND AUDIBLE BULB DOES NOT SEEM WORNOFF USED FOR 400HRS HOW CAN I NOW WETHER BALLAST OR BULB IS DEFECTIVE ALL VOLTAGES SEEMS OK I DONT HAVE SERVICE MANUAL IF I REPLACE BULB & SAME PROB PERSIST THEN? PLS HELP
  • 3 Answers
WHEN POWERED LAMP DOES NOT ON COLOR WHEEL SPIN SOUND AUDIBLE BULB DOES NOT SEEM WORNOFF USED FOR 400HRS HOW CAN I NOW WETHER BALLAST OR BULB IS DEFECTIVE ALL VOLTAGES SEEMS OK I DONT HAVE SERVICE MANUAL IF I REPLACE BULB & SAME PROB PERSIST THEN? PLS HELP E MAIL AT fakhruddinjawadwala@yahoo.com thanks
Posted on Feb 26, 2010
  • fakhruddin jawadwala Feb 28, 2010
    solve the above problem by replacing the bulb
    one can know whether ballast card is OK or not by following procedure
    1) select 1000v ac on good digital multimeter
    2) gnd black prode of multimeter to the chasis of projector
    3) place the red prode to pink wire of bulb
    4)switch on projector to green
    5) if meter show 200v reading then the ballast is OK bulb is defective this reading will be visible only for 3-4 sec then it will come to 0
    6) if there is no reading ballast is defective check fusible register and fet transitor
  • 2,237 Answers
May be either the colorwheel or the ballast. if you hear the colorwheel spin up (high-pitched whir), replace the ballast. if you don't hear it, replace the colorwheel.
Posted on Dec 31, 2009
Source for replacement bulb for Sawyers Slide Projector AQ707.
DYY EGH 120V 500W Light Bulb Replacement Lamp
Your bulb is a EGH or DYY (interchangeable) About $40 at this source
Projectors should be professionally serviced BEFORE Installing a replacement lamp to insure longevity. Never Touch the glass envelope; this will cause immediate failure, or shorten life considerably, (if you do touch the lamp thoroughly clean before illumination using alcohol).
Feb 08, 2018 | Office Equipment & Supplies
Projector not turning on
seems that the lamp is defective, pls test it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 25, 2014 | Optoma EP739 Multimedia Projector
Optoma HD70 bulb failure
I am betting that the ribbon cable to your color wheel has become loose. Here is a detailed slide show of a similar model so note where the cables are and check each one.
Optoma HD20 DLP Projector DMD repair turning green and flickering
Jun 25, 2013 | Optoma HD70 DLP Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
My projection television will stay on for awhile and then the screen goes blank and the projector turns off, my satelite, my reciever, my surround sound all stays on. I am left with a blank screen with no...
When you mentioned blank does it have light on. If not check the filter for cloggging as the heat build up on the lamp can trigger a stop. Use a good forced cooling to confirm.
If the picture is clear and there is no illumination issues the bulb must be good and the issue may be power based.
If the main power supply can be cooled off , does the fault apppear, if so check the soldering of the power supply.
unless all this is confirmed the problem of the suspected bulb can stay.
Sep 19, 2010 | Televison & Video
LP70 appears to be stuck in standby mode. The orange light illuminates immediately when the power is turned on. The bulb was just replaced.
the power supply needs to be upgraded which involves soldering a wire to the power supply then to the main board.
Jun 25, 2010 | InFocus LP70+ Multimedia Projector
Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Dec 16, 2009 | Kodak Ektapro 9020 Slide Projector
No illumination
make sure the power is coming on. if so, the contacts where the bulb is put in could be dirty/rusty/shot so you shoul make sure that is not the case and if it isnt then you should try calling customer service because there might be something wrong with the board.
Oct 14, 2008 | Epson PowerLite 62c Multimedia Projector
Sharp XR-10S DLP Projector Logo
370 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
