Question about Wolf Manufacturing KCHR629LP Range
Baked cookies are too brown around edges and not done in the center.
    President:
  • 2,976 Answers
Turn the heat down and get an air bake cookie sheet. They have holes in the underside.
Posted on Dec 11, 2009
Please guys help me, every time i baked the cookies , its always burned :(
The oven temperature may be too high. Get an oven thermometer and set it in the center of your oven and check to see if the temperature on your oven matches it. Many ovens run 25 degrees or more off of the set temperature. My mother's oven used to need to be set at 325 if she wanted it to bake at 350.
If the cookies are black on the bottom, but doughy in the centers, this may also be a case where the oven temperature is too high.
Another problem may be that you are baking them too long. Cookie baking is a precise thing. It may seem duh-obvious, but be sure you use a timer, lol. If the recipe calls for 10 minutes, and they are always burned, start checking them at 8 minutes.
If you are substituting honey for the sugar in the recipe, remember to lower the oven temperature by 25 degrees and decrease the liquids by a small amount to compensate. Honey browns/burns much faster than sugar.
Hope these suggestions help. =)
Aug 25, 2013 | Amana Microwave Ovens
How do they get the fortune message inside of the fortune cookie?
The fortune cookies are baked as flat circles. As they come out of the oven the paper is folded inside while they are still warm and then they are folded over to cool.
Feb 28, 2013 | Baking
My baxter rotating tray oven is not baking cookies evenly. The cookies on the outside of the cookie sheet are over-done and the cookies in the middle of the cookie sheet are not done ??
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Jun 14, 2010 | Baxter OV300E Stainless Steel Electric...
I have a Swiss Army watch from Eddie B It has a 20 mm brown strap genuine leather stiching around outer edges and half way down the center of strap giving it a thicker padded look. Where can I find a...
mcdevito75 Here, Hello Glen, with you knowing the MM size of the band, ebay is the place to look for a replacement.------------ In fact I have a 20MM strap in Black, made out of Rubber with a very lite Lizard design and stiching alond the edges, contact me ay mcdevito@netzero.com for details if interested.
Jun 14, 2010 | Watches
My baked goods are not turning out right. What is
Have you changed altitudes? Have you checked the actual oven temp with a regular oven thermometer?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 10, 2009 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
Temperature Contol
Replace the temperature sensor in the oven.
Jul 21, 2009 | GE Profile JB968 Electric Kitchen Range
Maytag oven overbakes or burns bottom of cookies, biscuits
Try this first, if the temperature is off contact me.
Put an oven thermometer at the center of the oven and set the oven to 350 degrees F.
Check the temperature indicated on the thermometer after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Apr 25, 2009 | Amana AER5515QA Electric Kitchen Range
Temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Thanks.
Dec 18, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Tappan gas range
that is a common problem if you want to be too fats with tappan. give it a little mor time on a lower(medium high) flame. You'll be suprised of the outcome
Apr 29, 2008 | Tappan TGF320 Gas Kitchen Range
Wolf Manufacturing KCHR629LP Range Logo
259 people viewed this question
Top Wolf Manufacturing Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Wolf Manufacturing Kitchen Range Expert? Answer questions, earn points and help others
