Question about ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC
Source code of 2 input numbers
How does code of java script ny the use of looping.
  • 28 Answers
Use c++
Posted on Dec 11, 2009
SOURCE:
My computer says it is running a script which will make it run slower. How do i correct this?
this is normally java running something, if it tells you its a different program close the program if not press Ctrl + alt + delete change to processes and pick java (it may have more in the name) right click and end process this should refresh java and stop it running excess scripts
Jan 09, 2014 | Computers & Internet
Which is the best one PHP or JAVA?
PHP is best one nothing, but Hypertext Preprocessor is an open source and this is one of the main reasons for PHP application development to be cost- effective and less expenditure. If you go for a development company, the only charges will be included for development and maintenance as the software is for free.
View source
http://www.openwavecomp.com/php_web_development.html
Nov 22, 2012 | Computers & Internet
When i enter the chat room i got the notice... a error has occured in the script on this page line:7 char:2888 error:permision denied code:o url: http://yui.yahooapis.com/2.4.1/build/con... min.js
You may not have Internet Explorer as your default browser but it is coded with Yahoo Messenger
For this reason you must keep it up to date and the support software as well. You do not have to set it as default but you need to keep itclean.
Flashplayer FOR IE
Shockwaveplayer FOR IE
Java
Check out the Yahoo Messenger Scripting Help page
1) Visit this page and select your product version (Messenger version) using the drop box
http://help.yahoo.com/kb/index?page=prod...
2) Type into the search bar: ......... script error...........and hit 'Search'
3) Browse the section for your problem and your OS and click on the link
To enable scripting:Internet Explorer8
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Restart IE Source(s):
Aug 18, 2011 | Yahoo Messenger
Wirte a pogram in java using for loop,that will print out the first 1 numbers of a fibonacii series that is:1 1 2 3 5 13 21 34 55
package com.gpt;
import javax.swing.JOptionPane;
This program computes Fibonacci numbers using a recursive
method.
public class Fibonacci
public static void main(String[] args)
String input = JOptionPane.showInputDialog("Enter n: ");
int n = Integer.parseInt(input);
for (int i = 1; i {
int f = fib(i);
System.out.println("fib(" + i + ") = " + f);
System.exit(0);
Computes a Fibonacci number.
@param n an integer
@return the nth Fibonacci number
public static int fib(int n)
if (n return 1;
else
return fib(n - 1) + fib(n - 2);
Feb 24, 2011 | Sun Java Programming Language (cdj-275)
How do i install java script being a guest
java script is not an installalbe item. java script is run inside the browser.
Dec 01, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Source code in java for notepad
you can downlaod source code here
http://www.planet-source-code.com/vb/scripts/ShowCode.asp?txtCodeId=3158&lngWId=2
Mar 23, 2009 | Computers & Internet
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
Can u please send me the follwing code. I want 2009 calendar with java script code ,so the code shoude be seen by clicking mouse it shoude be disply thanks, wish u ahappy new year
here it is. check the example available to see if it suits your needs.
follow the instructions and it will display in your web page.
you can
http://www.java-scripts.net/javascripts/Calendar-Popup.phtml
Jan 03, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Creating biodata form in java script
i want to create a biodata for every citizen and non-citizens in nigeria. how can i make it a dream come true.
Sep 08, 2008 | Computers & Internet
Help me to insert a java script
what is javascript of a button ceating in flash
Mar 29, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
Top ArcMedia Computers & Internet Experts
Alun Cox
Rob Hill
Rob Hill
Mike
Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
