Question about Sony KP-65WV600 65" Rear Projection HDTV-Ready Television
After the tv is turned on it turns off 3 or 4 times after turning it back on and the screen turns blue for a few minutes before becoming clear. It lasts longer each day.
    Top Expert:
  • Sony Master
  • 14,553 Answers
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now only available on a rebuild basis--usually not worth doing as the cost is very high.
You may have a bad blue picture tube but there is a way to deal with this first----the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue)
Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control (they are black like the block) With the set on(be careful) go to a video input After the tv is turned on it turns off 3 or 4 - clip_image001.gif with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 -500 parts and labor.
I do this here for free so if this has helped you rate this solution.
SD TECH
Posted on Dec 11, 2009
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
My Samsung T220HD was having problems turning on. The red light would flash once instead of 3 times, there would be an odd sound, and the screen would look a little weird. I would have to wait a few...
Many times the main circuit board becomes defective, especially after a power surge. If you had power fluctuations lately, the board could have become compromised. A shorted board needs replacement. Sometimes the cost of repair becomes greater than purchasing a new system.
Jan 14, 2018 | Samsung T220HD 22 in. LCD TV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
Cloudy Blue Color Covering Whole Screen
I think its time for sony to face a claas action, they do not supply parts in less than 7 years, and the unit should not have been sold so $high, they should buy them back, that is the best solution
Nov 14, 2008 | Sony KP-65WV600 65" Rear Projection...
BLUE SCREEN THEN SHUTS OFF
cause: tuner i believe will cause tv to not find channels turn blue and turn itself off
Aug 18, 2008 | Sony KP-51WS500 51" Rear Projection...
LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Image is grany every time tv is cold.
I had the same problem. Except mine never got better after the tv warmed up. I fortunately I still have my manufacturers warranty and Samsung sent a guy out within a few days. He replaced a few parts which really didn't do anything. However what he did that was interesting was on two circuit boards. One on the mid left and the other on the mid right. Apparently there is a nob or something he tweaked on each panel that cleared the grainy image right up. What he told me was that the it is basically pixels that are not turning off in sync. adjusting the two circuit boards syncs the pixels to turn on and off at the same time.
Nov 02, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Sony KP-65WV600 65" Rear Projection HDTV-Ready Television Logo
234 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
