Question about Pioneer VSX-D511 Receiver
Sub woofer I don't seem to be getting much base out of my sub. Could someone explain what cables I should be using. I have a powered Yamaha 8"cone woofer. Amplifier output-150W. Frequency response 25Hz-180Hz Power consumption 70w .
    Problem Solver:
  • 8 Answers
Is there a gain control on the sub? If not, are you using a receiver or pre/processor to control volume? There could be a level adjust or on/off control for the subwoofer output.
Posted on Feb 02, 2008
Just got two AR 312 HO speakers from my brother. I have a Yamaha HTR 6250. The speakers have (2) sets of cable hook up. One I assume is for built in sub woofers? Do I hook one normal and one to the sub...
do not use those speakers with that amp, those are 4 ohm speakers, which could damage your 8 ohm yamaha amp. you will have to get a 4 ohm capable amp to run the highs, and another 4 ohm amp to run the subs.
car amplifiers are currently 4 ohm, or even 2/1 ohm stable, but few, if any modern receivers can run at anything lower than 8 ohms without a danger of overheating. you may have to get a vintage amp(s), like a 1970's marantz receiver, or a 1980's to early 1990's kenwood power amp, because 4 ohm home amps are pretty scarce nowadays.
whatever amp(s)( you get, verify that they are DEFINITELY 4 ohm stable.
Nov 06, 2010 | Acoustic Research 312 HO Speaker
Yamaha rx-v2500 receiver how to hook up speakers
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
Jun 25, 2017 | Yamaha RX-V861 Receiver
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Dec 13, 2009 | Audio Players & Recorders
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Popping sound from sub woofer
disconnect the woofer and connect a different speaker see if other speaker makes the same pop if it don't then the woofer cone is defected if you have high watts and using stereo on high volume you can damage speakers.
Feb 08, 2018 | Yamaha HTR-5550 Receiver
Yamaha P4500 Power Amplifier 2-Channel Bridge mode
im from Yamaha service before and i know this model can handle as low as 2ohms per channel. I have to check on my manuals though if bridged. i dont see any reason why it cant. and it has a bridge option input stage... let me get back to you again in the days to come.
or email me
i have a service manual to check on this. got to dig on my closets..
Mar 14, 2007 | Yamaha P4500 Power Amplifier 2-Channel
Pioneer VSX-D511 Receiver Logo
75 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
