Question about HP DesignJet 800 Printer
HP 800 designjet plotter Error Message 21:10
Click menu button
Server error:0X3010002
Task: tMech
File: Sequence.c
Line 758
Need to replace service unit
Posted on Mar 22, 2010
    New Friend:
System Error 21:10
Severe Error:0x3010002
Task:tMech
File:sequence.c
Line:758
Posted on Jun 20, 2013
    Scholar:
  • HP Expert
  • 123 Answers
The 21:10 error indicates a problem with the service station. There is a 90% chance that replacing the service station will resolve the problem. Other possibilities are the interconnect board, the data cable from the interconnect board to the electronics module or the electronics module. Service stations can be ordered from: C7769 60149 Designjet 500 800 Service Station $79 95 Exchange for a refurbished unit or C7769 60149 Designjet 500 800 Service Station $169 Exchange
There is a belt replacement video that shows how to remove and replace the service station as part of the procedure. You may want to watch it before you decide to fix it yourself. On a difficulty scale of 1 to 10, this is a 1. 5 cover screws, to mounting screws and 1 connector - piece of cake. http://www.lpscomputer.com/pages/designjet-500-800-carriage-belt-replacement
Posted on Jun 02, 2016
3 Suggested Answers
SOURCE:
SOURCE: HP 800 designjet plotter Error Message 21:10
you would need to purchase a service unit and replace this is a common fault
BaronVonNuke
  • 1915 Answers
The service station on the printer has likely failed. This is the part of the printer that cleans the printheads to maintain print quality. Replacing this item requires diassembly of the printer and requires a certain amount of technical ability. If you are not afraid to take this on, you will need to contact HP and order Part Number C7769-60149.
If you are going to take this on yourself, post back and I can send you some instructions on the actual replacement of the service station.
Or contact an HP Designjet technician and have them replace it for you.
Posted on Mar 29, 2011
How to fix the following trouble message please thank you beforehand
This info is for technicians and explanations for the codes is limited to them
Jun 23, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
I am still having a problem with HP designjet 500 Plus showing error 86:01 then writing so:Severe error: 0 x 8010003 task: tMech file: sequence.c line: 636
sounds like the printer is broken pretty badly. Is it still in warranty? Contact HP for a replacement, or else it's time to buy a new one.
Nov 11, 2014 | HP DESIGNJET 500 InkJet Plotter Printer
Hp designjet 800 ps plus system error severe errora: 0x8010003 task: tmech file: sequence.c line: 636
Notate the error and put it in a search. Since it appears to be a server error, remove then reinstall the driver software.
Jul 09, 2011 | HP DesignJet 500 InkJet Printer
HP 800 designjet plotter Error Message 21:10 Click menu button Server error:0X3010002 Task: tMech File: Sequence.c Line 758
Mar 29, 2011 | HP DesignJet 800 Printer
We have a HP Designjet 4520ps plotter that is having the error message 79.04 According to HP this is a firmware error so we decided to try to update the firmware. We downloaded everything we could find...
dear sir/madam,
in this hp designjet 4520, this error comes up :error code 24:10. when i enter it, in the service manual it shows: Broken bag detected in Ink Cartridge. but it doesn
Mar 25, 2011 | HP DesignJet 4520PS InkJet Plotter Printer
It is about hpdesignjet 500 :- Problem- Severe error: 0X3010002 Task - tmech file - sequence.c line - 758 Please help I am using it in far away in salma dam project in afghanistan and no technical help...
System error 21.10 says to replace the service station/Aerosol fan Assembly.
You've got real problems if you don't have a service manual or parts.
good luck
Dec 05, 2010 | HP DesignJet 500 InkJet Printer
Hp designjet 500 does not work
You probably have a problem with dry ink in the service station. This is the "tank"on the right hand side of the plotter which collects all your wasre ink. I would have a guess that because of the long standing period this has dried and is preventing the station from moving and cleaning the heads. You will have to remove the right hand cover of the machine, then looking directly downwards just behind te display panel you will see two torx screws, loosen them. The service station can then be removed and cleaned. Be sure to disconnect the small plug on the service station motor and fan, also remove the motor and fan before cleaning the station with water under a tap. BEWARE this is a really messy job, your hands will be black (use dishwashing gloves) and it takes a really long time to clean it properly, wait for it to dry in the sun and re- assemble.
Good Luck
Dave
May 04, 2009 | Office Equipment & Supplies
System error: 21:10 - Severe Error ox3010002 - task:tMech - file:sequence.c - line:758
Well this is an old post but my 2 cents anyway...
Theres nothing to really fail on the service station besides the motor and that's highly unlikely.
As a service tech I find that it gets gummed up with in and needs to be broken down and cleaned.Warning, there's lots of parts and lots of half dried ink, so expect to spend an hour getting it out of the machine and cleaning.
Apr 15, 2009 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
"System Error" has occurred when the power is on.
same problem....what is the fix? - asap PLZ. In advance, thx
Dec 15, 2008 | HP DesignJet 5000 Printer
HP DesignJet 800 Printer Logo
3,230 people viewed this question
Clive
Clive
Thomas F. Schneider
