Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
My freezer is 50 degrees and my fridge is 60 degrees. i try to set the thermostat but it keeps jumping back up. what can i do?
  • GE Master
  • 4,655 Answers
Because your model is a GE Artica Profile I can tell you that something simple is causing a major problem for your refrigerator.Those models come with a mother board that is sensitive to different fallures that rapidly damage the board. Sometimes a fan under the refrigerator will run and because it may be going bad will stop, When that happens the compressor gets hot and can not run and then the compressor can not remain cool by the returning cold freon from freezer, This is a Job for a honest and knowledgeable technician. If he or she should come out and just rush through the job they seem to miss the fact that other problems may be causing this, So look into the rear of freezer at 50 degrees there is no frost on the back wall meaning the compressor is not running but may sound the same.You will need service now. Do not leave it plugged in until repaired. I wish I could come by and fix that one and not be given a time line to eliminate every possibility. That is when they rush through and miss something and come back and charge you again. Your are welcome to my assistance if you have someone that can use a multi-meter and knows how to work on electronic and electrical parts, The first thing I would do is see what condition the compressor is in.Then fans and then to the board, Depending on the warranty sealed parts are 5 years on the compressor. I may be wrong but I would check into that, Most likely something like a fan, start capacitor, start relay and overload may have also damaged the motherboard. I will be back soon with a manual and a way to find me if you like, Sea Breeze
Posted on Dec 11, 2009
For the past couple of weeks, the freezer will loose its cool enough to thaw or partially thaw what is in it, but two or three hours later it will be frozen again. Keeps going back and forth. Ideas?
possible problem thermostat or freezer setting to close to one setting
reset to a bigger number as the numbers work opposite to the fridge settings ( 1 is close to 0 degrees and 20 is -20 degrees ) where as in a fridge 1 is close to 0 degrees and 5 is + 5 degrees above 0
Sep 10, 2016 | Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
Fridge not getting cold.....still
Hello Nick,
Don't let your frustrations get the best of you...
WE can do this...!!
Defrost consists of only three (3) parts...
- Control board (or timer, not in your case:
(see below)).. A common problem.
- Defrost heater element (to melt the "FROST"
(seldom fails)
- DEFROST THERMOSTAT
(to keep the temp DOWN)
The EASIEST but most expensive part is the
DEFROST control board.
Take lots of pictures before removing any wires.
Main Electronic Control Board
Mar 07, 2017 | GE Profile PDS22MHR Bottom Freezer...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Have a dometic ndr1292 side,freezer works fridge at 60 degrees
Try to defrost it. unplug fridge and place a box fan in front blowing at it. keep the frigd controls in the midle range as well as the freezer control
Sep 05, 2009 | Refrigerators
Frig too warm, freezer works great, but frost on back wall
It sounds like the fridge is not going through the defrost cylce due to a faulty defrost thermostat.
Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
266 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
