Question about Lexmark X2650 All-In-One InkJet Printer
Cannot print microsoft office and it says that check the cable connection but it can scan in my computer
  • 330 Answers
Check the printer status in control panel ...printer and faxes it should ready mode if its in offline right click on the printer driver and select use in online one more thing right click on the printer and go to properties then go to port check which port selected ...... select usb port ... and check .....
Posted on Dec 11, 2009
SOURCE:
How do I scan to PDF?
w10 has this built in
so what PC is this what OS?
HP now owns samsung printers .
there are only 4 ways,
use w10 print engine way,
use HP way if offered, ask them yet?
or scan to JPG
and use and app to publish jpg to PDF, I use NITRO.
or buy PDF engine driver, to do that.
Samsung SCX-4521F Laser Multifunction Machine Print/Copy/Fax/Scan
Sep 18, 2018 | Samsung Office Equipment & Supplies
How do you scan a document to MS-Word?
You actually have 2 options.
First Option: (You can also see the instructions here.)
How to Turn a Scanned Document Into Microsoft Word Document:
1)Scan the page you want to convert into a Microsoft Word document.
2)Save the scanned image in *.gif, *.jpeg or whatever format.
3)Open that image, go to "File->Save As" and name it "xyz.tiff" in the "TIFF" format as shown.
4)Go to "Start->Programs->Microsoft Office Tools->Microsoft Office Document Imaging"
5)Go to "File->Open" and open your scanned document that has been saved in *.TIFF format.
6)Go to "Tools->Send Text to Word." You will get a prompt stating this process will take time, Click OK. This will take some time depending on your computer's speed (a minute or two at the most).
7)When it's done it will open up Microsoft word on its own and the scanned document will now be in editable mode.
Second Option: (You can also see the instructions here.)
Install Microsoft Office Document Imaging:
Follow the instructions based on the operating system that your computer is running.
For Windows Vista Users:
1. Exit all programs.
(Tip You may want to print this topic before you exit all programs.)
2. Click the Start button Button image, and then click Control Panel.
3. In Control Panel, click Programs, and then click Programs and Features.
4. Right-click the name of the Microsoft Office edition that you installed or right-click Microsoft Office Word 2007 (depending on whether you installed Word as part of Office or as an individual program), and then click Change.
5. Click Add or Remove Features, and then click Continue.
6. Under Installation Options, click the plus sign (+) next to Office Tools.
7. Click the arrow next to Microsoft Office Document Imaging, click Run all from my Computer, and then click Continue.
For Windows XP Users:
2. Click Start, and then click Control Panel.
3. In Control Panel, click Add or Remove Programs , and then click Remove a program.
4. In the Currently installed programs list, click the name of the Microsoft Office edition that you installed or click Microsoft Office Word 2007 (depending on whether you installed Word as part of Office or as an individual program), and then click Change.
The Configuration Wizard opens.
Create a document that you can edit
Scan your document according to the instructions for your scanner.
Before you continue Convert the file that the scanner created to TIFF format. You can use Paint or another program to convert the file.
1. Open Microsoft Office Document Imaging by doing one of the following:
In Windows Vista Click the Start button Button image, click All Programs, then click Microsoft Office, click Microsoft Office Tools, and then click Microsoft Office Document Imaging.
In Windows XP Click Start, click All Programs, click Microsoft Office, click Microsoft Office Tools, and then click Microsoft Office Document Imaging.
2. On the File menu, click Open.
3. Locate the document that you scanned, and then click Open.
4. After Microsoft Office Document Imaging runs, press CTRL+A to select the entire document, and then press CTRL+C.
5. Start Microsoft Office Word.
6. Click the Microsoft Office Button Button image, and then click New.
7. Click Blank document, and then click Create.
8. Press CTRL+V to paste the contents of the scanned document into the new file.
You now have a document that you can edit. Be sure to save the new file so that you don't lose your changes.
Hope this helps!
Apr 06, 2011 | Office Equipment & Supplies
Will not scan my photo
It is difficult to provide a diagnoses with so little information...
Providing that your Printer is talking to your computer correctly, use the Microsoft Office Document Scanner software in Start/All Programs/Microsoft Office/Microsoft Office Tools, if you are running XP Pro.
If it an issue with your printer, check the connection through Printers and Faxes in the Start Menu, by printing a test page. For installation/configuration, consult your manual because there may have been a step you missed
Apr 16, 2010 | Canon PIXMA MP470 All-in-One Printer
Slow typing response
Shutdown all non-necessary programs (Winamp, LimeWire) to reduce the "load" on your computer.
Disconnect your computer from the Internet (unplug the Ethernet cable or disable the wireless connection).
Then, launch MS Word.
Virus-scan your computer -- some computer-virus may be consuming resources.
Nov 11, 2009 | Microsoft Office Word 2007 Upgrade Version...
Scanning issues
You can scan the document by using a Microsoft Word or any other Office Package,
To scan using microsoft office, please follow steps given below
Select Insert - Picture - From Scanner or Camera
Select Insert
This should work, if so please vote for me
Aug 24, 2009 | HP Photosmart C6280 Printer
HP photosmart C5580 How scan to computer?
scanning through bluetooth is not possible bluetooth module only pairs the computer and printer and has link only to the basic driver of the computer so you can only print from it
if you want to scan you should connect te usb cable or use a wireless upgrade kit
Aug 10, 2009 | HP Photosmart C5580 All-In-One InkJet...
My kodak esp3 will not scan it prints and copies.
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
May 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
KODAK ESP-3 AiO Will Not Scan On Vista 64 Bit Ulitmate
Feb 16, 2009 | Office Equipment & Supplies
Scanner not detected by Microsoft Office Document Scanning
1) Install the Microsoft Office Document Imaging feature by following the steps
given below:
1) Go to Start -> Control Panel.
2) Click the Add or Remove Programs.
3) Select the Microsoft Office Professional Edition 2003 and click the Change
button.
4) Click the Add or Remove Features and click on Next.
5) Select the Choose advanced customization of applications checkbox and click
Next.
6) Click on the Office Tools -> Microsoft Office Document Imaging -> Scanning, OCR
and Indexing Service Filter.
7) Select Run all from My Computer, insert the Office installation CD, and the
feature is installed.
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Epson dx3800 stopped printing. I get a communication error message. All cables etc checked, scanner works and printer will print scanned article when not connected to computer. Seems files cannot be...
To get over this problem, First uninstall your printer and reboot your computer and again install the driver of printer and if the problem persist then consult Epson Printer Support team and get connected with the expert technicians of the customer service by just dialing 1-800-243-0019(toll free) and get your issue resolved in a short span of time.
Sep 02, 2017 | Epson Office Equipment & Supplies
Lexmark X2650 All-In-One InkJet Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
