EMachines Imperial GL VE-20021218 Motherboard Pin Out
I have a emachines that ate the motherboard listed above. I purchased a ASUS P4GV-LA motherboard as a replacement. The pin out for the LED for the HDD, Power LED and On/Off switch do not appear to be present on the ASUS motherboard. I want to obtain a pin out for the Imperial motherboard and compare it to the ASUS motherboard to make sure I do not fry the new motherboard. Any help with the configuration of either M/B would be greatly appreciated.
I have an HP pavillion a305w with the same Imperial MB, and I replaced my MB with an ASUS P4SGX-MX.
from your case, the yellow/black goes to the IDE Led, the green/black goes to the POWER Led, and the red/black goes to the POWER SWITCH.
Posted on Aug 21, 2008
  • 417 Answers
Normally on the board there is silk printing to state what connection goes where. Also on the black connector i.e. power LED there is a small arrow that goes to pin 1 of the POWER LED pins.
Hope that was any help thanks J
Posted on Jan 20, 2008
Emachines Imperial GV 20030812 Motherboard manual
THE MOST EASY WAY TO CLEAR CMOS JUST REMOVE CMOS-
BATTERY FOR 10-20 SECONDS.IT LOOK LIKE A WATCH-BATTERY.BE CAREFULE WITH THE HOOKS.
Dec 03, 2013 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Emachine Wiring Diagram
What a Marvelous person!
You have described a 4-pin Peripheral power cable, ('P6'),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
An IDE harddrive, of which the 4-pin Peripheral power cable example, is plugged into.
Another look at an IDE (PATA) harddrive,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136096
http://en.wikipedia.org/wiki/Parallel_ATA
However, I do not know if the flat IDE ribbon cable marked Slave, goes to a secondary Harddrive, or an optical drive. (CD/DVD drive)
Either way the point is moot. BOTH of those 'squarish flat black' units, HAVE a 4-pin Peripheral power cable to them.
Another hardware component, those type of power wires CAN go to, is a computer case fan.
However not ALL power cables have to be used. Sometimes there are extra ones. These are in case they are need later.
To summarize;
The optical drive, or drives; that you put a CD, or DVD disk in; can use a 4-pin Peripheral power cable.
(IDE/PATA optical drive)
Harddrive's can use a 4-pin Peripheral power cable.
(IDE/PATA harddrive)
A computer case fan may use a 4-pin Peripheral power cable.
Or the 4-pin Peripheral power cable you see, may simply be an extra one. One if needed in the future.
The eMachines T2245 uses a Trigem (Manufacturer), Imperial GLVE (Model name), motherboard,
http://www.ebay.com/itm/New-Emachines-Imperial-GL-VE-20021218-Motherboard-Socket-478-System-Board-/121098707716?pt=Motherboards&hash=item1c320ba304
Supports an IDE (PATA) harddrive, (Or 2 of them)
Supports an IDE (PATA) optical drive, (or two of them)
I DO hope you are following Anti-Static Procedures!
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static, BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open, empty computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
Also I would like to add;
http://computer.howstuffworks.com/
http://www.hardwaresecrets.com/article/Anatomy-of-a-Hard-Disk-Drive/177
http://www.hardwaresecrets.com/article/Anatomy-of-an-Optical-Drive/179
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 24, 2013 | eMachines Emachine T2245 Power Supply...
I want an Imperial GL VE 20021111 motherboard manual
Get all information about the motherboard from here...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07813&lc=en&dlc=en&cc=us&lang=en&product=307585
best of luck!
Mar 07, 2012 | Computers & Internet
Need the pin assignments for the mother board
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site (ASUS) to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | HP Compaq Presario SR1420nx...
How to connect front panel connectors to front panel headers on a imperial GL VE 20021218 motherboard
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
May 30, 2009 | Intel Computers & Internet
I need the name of the motherboard used in the Compaq Presario SR1410NX so I can look at the manual.
HP lists the Motherboard as an Asus P4GV-LA.
Here is the support page for your computer:
SR1410NX Support
Click on Product Information to get the specs for it, including motherboard info.
Unfortunately Asus does not list this version on their support site but HP has quite a bit of info on the link listed below.
P4GV-LA Specs
Thanks for using Fixya.
May 20, 2009 | Compaq Computers & Internet
ASUS P4GV-LA motherboard swapout
It's true that P4 boards are not manufactured any more. But again, are you sure that it’s the motherboard which has problem, the SMPS (power supply might have some problem.) might be faulty too. Check the SMPS first.
Mar 14, 2009 | Acer Veriton 7100 PC Desktop
W2646 crapped out
Some eMachines computers (like many from Dell) use a non-standard pin out for their power supplies, so if you try a standard ATX power supply it may not function.
However, in my experience it IS likely to be the motherboard. Luckly I have been able to replace quite a few of the eMachines mobos with a standard mATX mobo, since you can probably remove the IO plate. You'd certainly want to replace the power supply when doing so.
Jan 25, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
3,958 people viewed this question
David Payne
David Payne
