I was in the process of instaling windows vista after i just formated my hard drive, towards the end of the installation the screen randomly turned off, and would not come back on. I restarted the computer and it gave me a beep code of 1 long beep and 2 short beeps. This is all well and good but i have no idea what my bios manufacturer is and i cant find it anywhere. As stupid as i am i went and bought a replacement motherboard for it, but to no avail same problem. None of the video ports work, so im thinking it could be the display adapter? Which is a geforce go 7600 It is not intergrated into the motherboard. Can i replace this with a different video card perhaps? something better for future gaming. Any ideas? thanks
    Guru:
  • 480 Answers
If the VGA card is not integrated you can replace and see.
Normally we experience this type of error with faulty VGA card
Regards
Uttam
Posted on Dec 11, 2009
..pls teach me how to
You need to purchase Windows Vista, once you have the disc with you, then you can start the Widnows installation process. during the process you can choose to format your hard drive and install Windows.
Feb 28, 2011 | IBM TravelStar 40GN 40 GB Hard Drive
Installing XP on a vista computer
Before beginning please note the following:
All your data will be erased by the end of this process.
Also I recommend to switch to Windows 7 (instead of XP) as they are far better and faster than Vista and XP. If you can switch your XP for Windows 7 then you should do that.
However the decision is yours.
Nothing else should be done except to backup your data.
Then, insert the XP disc in your dvd drive and restart your computer. When the message "Press any key to boot from CD" appears press enter.
When the XP setup loads, select to format your hard drive and install a fresh copy of XP. Follow the on screen instructions and you will have XP on your system in about 30-45 minutes.
Regards,
nicolasiac
Jan 28, 2010 | Microsoft Windows XP Professional With...
I want to do partition of my hard disk.So please help me
You need to partition your hard drive before you install an operating system on it. If you boot off your windows CD and your hard drive has a partition already you will get a screen that prompts you to format it. You can also dellete the partition and make a new partition. AT that time you can select the size of the partition you want to make and creat multiple partitions. If you choose you can creat one smaller partition from the space available for you to format and install windows on and format the rest of the available space later on after windows is installed from the Administration Tools in control panel.
Jun 02, 2009 | Microsoft Windows Vista Ultimate Edition
Stepbystep procedure for formating
Hello jerapur_123 What you'll need:
  • Recovery CD or Restore CD from the MFG
  • WIndows Operating Disk 98 or ME, 2000, XP or Vista.
  • A CD Rom Drive
  • Or a Floppy for low level formatting.
Key Steps to Formatting
Back it Up!
Before the format process, you want to make sure that if your goal is hard drive recovery, you back-up as much personal data and information from your hard drive as you need. In some instances where a virus has caused serious system damage, this may not be possible, but if your format is planned ahead of time you certainly can copy and archive data off your hard drive before you start the format process.
How to Format
If you purchased your computer from systems vendor such as a Dell, HP Compaq or Gateway system, you most likely will have a set-up or a restore-and-recovery CD (also referred to as a master CD) that came with the system. If this is the type of system you use, then a format is an easy process as the master CD by inserting the CD into your CDROM, will format the hard drive, reinstall your Windows operating system, and install any software and programs that came with the system. If you no longer have your master set-up CD, you should contact the manufacturer to get a replacement.
How to Format without a Recovery Disk:
If you aren't using this type of mass-market system, then a hard drive format will consist of you formatting the hard drive manually, installing your Windows OS from CD, then installing your software programs and hardware drivers. Before you begin the formatting process, it is important to make sure you have all your driver CDs located, Windows CD and your software CDs to ensure a smooth set-up.
It's also important to know about your operating system before you format. For example, if you're going to be reinstalling an older version of the operating such as Windows 98 or Windows ME then you should have a Windows 98 or ME start-up disk to complete the procedure. In this instance, you would restart the system with the start-up floppy in the drive. Upon system boot, you will choose to have CD-ROM support. Once the files load you can then choose to run the format command on your main drive (usually C drive). If you are using Windows 2000, Windows XP or Windows Vista the Windows installation process offers "format your hard drive" as an option. Here you would ensure your computer is set to boot from CD-ROM (a setting in your system BIOS), insert the Windows CD and restart the computer. From there you will be on your way to reformatting.
As you can see there are many options to formatting a hard drive. Hopefully this gives you a good understanding that most of the operating systems today do the formatting for you, all you need to do is pick that option as you follow the onscreen steps when you install either your Restore, or Operating System.
Good Luck,
Mark
Please don't forget to leave a rating.
Feb 18, 2009 | HP Computers & Internet
I have an IBM thinkpad, an old one from work, nad it has another user name and password that I do not know. Id like to format the hard drive and install Vista on this, currently it is W2000 pro. Would you...
You don't need to get a command prompt to format the hard drive.
Just boot up with the CD as the first boot device. Press F12 just after you switch on the laptop, then select the CD as the temporary boot device, insert the Windows XP install CD in the drive.
When the install process starts and displays the partitions, delete the existing partitions, then create a new partition, and then do a full NTFS format, not a quick format.
Now ou are on your way for a new Windows install.
Jan 01, 2009 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
