Question about Acer TravelMate 240 Notebook
About 5 seconds of start powers on it beeps 4
Powers on About 5 seconds of start it beeps 4 times slowly and then turns off. Accer Travelmate 240
  • Acer Master
  • 3,866 Answers
Sounds like you laptop overheated at one point as common 5 beeps are CPU/GPU things to check:
1. clean out your vents
2. The laptop may need to be evaluated by a local tech to see witch unit failed cpu/gpu.
We are here in chat 24/7 and can help you alot better then over email but if you prefer the free option then qaulity does suffer as we do not have a two way communication to find out what caused this. You might just want to pay the pipper @ bestbuy and get it fixed. or start a paid chat with us :) ether way here you going to need the part to fix this so you decide.
Thanks for visiting fixya.com please do rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 11, 2009
Powers up, get four beeps, then powers down
System Timer Failure
But it matters what motherboard you have.
http://www.computerhope.com/beep.htm
This is the link I use to get started.
Apr 18, 2013 | Acer TravelMate 240 Notebook
TURNS ON AND GET A BEEPING NOISE THEN TURNS ITS SELF OFF AFTER A FEW SECONDS
Remove your memory stick and clean it with some alcohol or use a rubber eraser to clean it, then fit in slot. This may help to work the PC.
If NO...
It can also be overheating with laptop, is it hot when its turned off? can you start immediately after the shutdown? try to reply to these requests.
Dec 17, 2010 | Acer TravelMate 240 Notebook
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    The beeping is a BIOS error on an acer 240 travelmate how to fix
    Follow this link and it will tell you what the beep code is saying. You will need to count the beeps and it will be listed here at this site what the codes mean. Once you find out what the problem is, we can begin the trouble shooting process. Heres the link, hope this helps!
    http://www.bioscentral.com/beepcodes/phoenixbeep.htm
    Lori
    www.computersolutionsbylori.net
    lori@computersolutionsbylori.net
    Feel free to leave ratings!!
    Oct 12, 2010 | Acer TravelMate 240 Notebook
    My acer travelmate 250 wont start up whaen i switch it on its just a black screen and it bleeps 3 times then just knocks off
    If you are getting beeps on startup and nothing shows on screen possibly the RAM of your system is gone bad.
    You might try reseating the RAM to get this issue fixed, If you have more than 1 memory stick try loading one stick at a time to understand which of the RAM is gone bad.
    Jul 15, 2010 | Acer TravelMate 240 Notebook
    Acer travelmate 290 beeping, starts with blue screen and then black and beeping
    See if there is an error beep. If there is an erro beep, then change
    main board.
    Power off. Then check if RAM CPU BIOS are well-connected.
    Press Fn+F5 three times slowly
    LCD FPC
    LCD inverter
    LCD
    USB does not work correctly USB device cable is firmly connected into the USB ports. Test
    Oct 29, 2009 | Acer TravelMate 290 Notebook
    Acer Travelmate beeps 4 times & wont boot
    Sounds like a RAM problem. Best bet is to purchase a stick of RAM from a store that will let you try it and return it if the problem is not solved. The beeping is a BIOS error code that signifies that something is wrong with your hardware.
    If you have 2 sticks of RAM installed try removing one of them and then if the beep code happens again try to swap them out.
    Sep 26, 2009 | Acer TravelMate 240 Notebook
    Acer Travelmate 290 laptop beeps all the time
    try to turn off the alert sound on connectivity and time event from windows.
    hope this works.
    Jul 11, 2009 | Acer TravelMate 290 Notebook
    Acer travelmate 4000 laptop Big problem
    I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
    Aug 23, 2007 | Acer TravelMate 2300 Notebook
    Acer TravelMate 240 Notebook Logo
    109 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
