Question about HP Photosmart C5180 All-In-One InkJet Printer
Photo Paper won't feed through printer - HP Photosmart C5180 All-In-One InkJet Printer
SOURCE: olympus ilp 100 photo printer
I had the same problem. My guess is something in the printer broke in some fashion, and this is a common weak point of the printer itself. I ended up buying a replacement printer. I must say that I LOVE the prints that this printer makes, and it's so easy to use that my wife and 14 year old son can use it with no problems. The prints are FANTASTIC, and look just like a film photograph print !!! It is that good! And... the cost is about the same for film prints (with none of the cost of the film or developing), with all the convenience of doing it at home, on demand. WOW !
Posted on Jun 19, 2008
adonscott
  • 106 Answers
SOURCE: Photo Paper Feed
hi,
the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
Thank you so much.
adonscott
Posted on Jul 07, 2008
  • 5 Answers
SOURCE: dell 926 photo printer paper feed
There is something jammed in the pick up roller area.
Posted on Aug 09, 2008
SOURCE: Power on switch and orange arrow flashing, will not feed or print.
I had the same problem and found this solution. It worked for me, hope it helps you too.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09315&lc=en&cc=us&lang=en&product=60653&dlc=en
Posted on Aug 25, 2008
  • 111 Answers
SOURCE: Photo Paper Jams
Based on your question, my first thought is that you changed the type of photo paper you used starting "this week" (when you first posted your question). If you did, the photo paper size/thickness may not be compatible with your printer.
Otherwise, there may be a problem with the paper sensor. Click on the following link and review the troubleshooting steps, particularly Step 2, to see if that helps:
Paper Jam Troubleshooting
Post back your results. If you are still having the problem, post any additional information you think might help solve the problem. Thanks and good luck.
Posted on Oct 03, 2008
PHOTO PAPER NOT FEEDING
adjust the paper thickness of the printer as photo paper is thicker than ordinary print paper
Jul 30, 2016 | Office Equipment & Supplies
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
Won't load paper
Clean the paper feed with alcohol and a paper towel by rubbing and rotating the drum. Wait for it to dry completely then it should grab the paper. Also make sure paper is free from dust. Good luck!
Jan 25, 2013 | Kodak EasyShare Photo Printer 500
Canon ip2600 won't feed paper
I fixed mine!! I cut a letter size paper in half lengthwise (so it was skinny and long). Held the printer on my lap with both top and bottom trays open. I noticed the white pegs and skinny black roller inside were turning when I turned it on, so I waited til they were spinning and slid the paper between them along the right side. (Kind of a reverse feed). Had to do it between the crazy ink returns. Yes, the paper crumpled a little, and I did it a couple of times with a couple of papers. Something gave, because after that it started feeding properly again!
Oct 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Plain paper feeds no problem but photo glossy paper wont feed! (epson 830)
Hi
This looks to be a problem with the paper pickup roller. Hence use a little thin Photo paper or replace the Pickup roller and also the Paper feed toller (Long black roller )
Jul 15, 2011 | Epson Stylus Photo 830 InkJet Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Wont feed glossy photo paper
Clean the feed roller(s) with a cloth dampened with alcohol. They are probably slippery with paper dust.
Mar 17, 2009 | HP Photosmart C5180 All-In-One InkJet...
Print head alignment +won't feed paper
Best solution is to clean the head with it in place,here's
the manual for your printer
Oct 09, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson stylus pohoto 830u paper feed
I'm afraid this series of printer (810 -830) doesn't handle heavy photo paper well - which is a bit strange for a so-called photo printer. If you hold each sheet and help it to feed it will work. But ...... for goodness sake. Your best bet is to sell it on e-bay and buy something that will handle heavy paper.
Jun 12, 2008 | Epson Stylus 830U InkJet Photo Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
190 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
