Question about Dirt Devil Royal Cordless Rechargeable Sweeper Vac with Swiffer Vacuum
Swiffer repair parts? specifically the felt
Where to get swiffer repair parts? specifically the felt washers that (sort of) seal the gear boxes
Agitator Rattling
There are no washers of any sort on the Dyson's agitators. There are molded caps on each end, made to fit into the bracketry on the sides of the nozzle portion. If there's it seems as though there's something missing then you'll need to purchase a complete agitator, there are no replacement parts for agitators.
Nov 08, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
I was replacing the belt on my Eureka Smartvac 4870 and one of the felt gaskets (or part of it) popped out. I thought I put it in correctly, but the first I used it after replacing the belt, the gasket got...
I'm no expert but if you mean the felt on the roller, you have to replace the roller (expensive,esp. for such a minor part). So. I found some felt with adhesive in the craft section at Wal-Mart, trimmed it to fit and done deal. Felt reduces friction.
Dec 08, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
I am looking for a specific part for a Nostalgia Electrics RIC-100 portable ice maker and I am finding it very hard to find what I am looking for if I could get some help that would be great. The part I...
Try to google for it but if unsuccessful you may have to resort to some sort of repair that will do the trick. May not look great but if it works, then.............................
Aug 24, 2017 | Vacuums
My sebo x4 extra does not start. There is power but no warning lights are flashing. When I turn the vacuum on there is a continual clicking/buzzing sound.
Hi.
Eeither motor or servo motor with gear box is seized. Testing is done energizing the motor. Test and repair must be done by a technician. Call the number listed on the owners manual to contact a qualified repairer.
See: Parts List and schematics SEBO X4
Jul 31, 2010 | Sebo X4 Bagged Upright Vacuum
Vax carpet washer deluxe leaks from bottom of water tank, somewhere between coming out of the tank and going into the jet to squirt on the floor. pissing me off - any help would be great!
This is a common problem known by repairers. What happens is residue gets stuck in the seals. The next time you use the machine and press the trigger the seals stay open and water leaks continually. It was suggested that maybe after you finish using the machine you do a whole tank of plain water to rinse it out but I haven't had any luck with that. I am stuck with a machine that doesn't work.
May 06, 2010 | Vacuums
Clarification to elextek: The right side
If the valve itself is leaking, it needs repaired/replaced. There should be a plastic stem in it, with a rubber seal washer, and a coil spring to close the valve stem when removed from the cleaner. If these parts are not there, or stuck, it will leak.
Oct 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The brushes stopped turning
just repaired mine today same problem.
Turbine drive shaft which drives two sets of plastic gears and which in turn make the scrub brushes rotate has sealed ball bearings and I guess from an evidently poor design moisture some how entered plastic gear casing and the sealed bearings froze up which evidently aren't sealed all that well. Anyway (turbine drive after easy removal from unit 8 screws on bottom one on top can be disassembled by removing 4 screws around gear casing allowing access to the plastic drive gears and the bearings) You can make a decision from there of whether or not a new replacement turbine is a better way to go.
The entire turbine unit can be purchased online for a very reasonable price if you look around the Web.
Dec 19, 2008 | Hoover F7431-900 SteamVac Vacuum
Dirt Devil Royal Cordless Rechargeable Sweeper Vac with Swiffer Vacuum Logo
778 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
