Question about Grilling
MY LER5636EQ3 dryer will not start. I can hear it running at the cycle knob but it does not start,
  • 57 Answers
This sounds like it is waiting for something. Probably either a door closed signal of a start button signal. Check that the door closed switch is connecting (you should be able to hear a faint click)
Posted on Dec 11, 2009
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Whirlpool dryer wont start LER5636EQ3
The thermal fuse it probably the problem,jump it out to make sure but DO NOT leave it that way if it does work or you could burn your house down.Thwen be sure the vent is clear and the thermostat is cycling the burner.Good Luck
Jul 22, 2014 | Whirlpool Dryers
My Whirlpool LEB6300PWO will randomly not start, or will start but only run briefly then stop. I know these types of problems are not usually related to the timer, but we have found that by either lightly...
Hello, we are sorry to hear that you are having this problem with the Dryer. We would recommend having a certified technician out to take a look at the Dryer and give a proper diagnosis. If you would like further assistance you can reach out to us with your name, phone number, address, model/serial number and the date on which you purchased the Dryer to Whirlpool_Reviews@Whirlpool.com.
Apr 17, 2017 | Whirlpool LEB6300 Electric Dryer
Whirlpool Dryer Model LER5636EQ3. Runs for several minutes then stop.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2011 | Avanti D110 Electric Portable Dryer
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
Eurotech dryer. ON light flashes on and off, beeps once, and still flashes then nothing happens, dryer won't start. Help?
The problem is that you stopped a cycle before the program knob reached the "STOP" (12 o'clock on the knob). All you have to do is turn on the machine, turn the knob to STOP, and wait a couple of seconds. You'll hear a tone and the ON/OFF light will stop blinking. Turn the program knob to the cycle you want and- viola! you're good to go!
May 20, 2010 | EuroTech EDC158 Electric Dryer
Buzzing noise when i turn the timer switch
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer ran fine. Next load it would not start. It is a 220V, 5 cycle-3 temperature unit. Model # LER5636EQ3 TYPE: 178-00
Check your door switch to make sure its ok. Whirlpool has a fuse on the back of the machine inside. Fuse will be white in color. If that is open, check for a clogged vent or ck your hi-limit thermostat. If everything else is ok you have a bad timer.
Sep 10, 2009 | Dryers
I have a whirlpool dryer LER5636EQ3 that will shut off after 3-5 mins.
Go to www.repairclinic.com and enter LER5636EQ3. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Whirlpool video that shows disassembly and identifies major parts.
May 18, 2017 | Whirlpool Dryers
Grilling Logo
43 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
