Question about Philips 9P5544C 55" Rear Projection Television
Where can we find a replacement bulb for 9p5544c102
  • Philips Master
  • 3,459 Answers
Your TV uses tubes - red - green - blue - tubes.
What is the issue? These tubes are fairly hardy in the Magnavox TV sets.
Posted on Dec 11, 2009
SOURCE:
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
9p5544c102 Horizontal bow
ok meoff check the convergence circuit. shadow in the picture is defective convergence circuit... replace a new.
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Jul 14, 2010 | Philips 9P5544C 55" Rear Projection...
Phillips/Mag Projection TV-9P5544C102 no pic/sound /pwr light on
John, my thoughts is something in the main power supply. I don't know what an opto chip is but I've heard of Optocupler IC's.
May be a good idea to give a call to some local TV Repair Shops especially ones that work on Philip's and see if you can speak with a tech to see what their thoughts are on what the problem is and what a repair cost may be.
The issue is one of hauling it to the TV shop or having them come out to you.
Blessings,
A/V Media Guy
Nov 20, 2009 | Televison & Video
55'' philips rear projection turns on no video/audio. 9p5544c102
Try removing the two convergence chips from the board - then see if the TV powers on and lights up. If so you narrowed it down. If not - you have eliminated convergence IC problems.
Nov 04, 2009 | Televison & Video
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
I have a Philips 9P5544C102
Tom You are experiencing a convergence output failure. The crosses will not move until the conv.. chips are replaced with original parts. There are also some yoke return resistors that have opened due to the chips flaking out. John
Sep 11, 2007 | Philips Magnavox 9P6034C 60" Rear...
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Philips 9P5544C 55" Rear Projection Television Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
