Question about D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch
DES-1005 in HUB working mode?
I'm trying to analyze a networking problem with wireshark, but only have a D-Link DES-1005 switch at hand.
Is there a possibility to set this device into a hub working mode to capture all frames?
    Novelist:
  • 139 Answers
Unfortunately, the DES-1005 can not be configured to behave as hub and send all the packets to your analyzer software.
Do you have a manageable switch available. Most manageable switches have a "port mirroring" or "monitor" function that allows you to copy all the traffic passing through one port to another port...where the wireshark can receive it for analysis.
Posted on Jan 20, 2008
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Download Driver D-link DES-1005A
yesi need a driver setup disk i lost one
Feb 09, 2012 | D-Link DES 1005 Ethernet Switch
Getting low or no connectivity error when trying to connect laptop and other devices to 5-port DLINK switch. Lan line going to switch is confirmed working as i'm able to plug the laptop and other devices...
please change the cable which is connecting your laptop to D-Link DES 1005 Ethernet Switch.
This error appears when you have either a bad cable or bad switch or NIC card on Laptop.
As you have Laptop and other devices and getting the same error , so i suspect issue with the cable.
Please use a new Straight LAN cable.
Oct 31, 2010 | D-Link DES 1005 Ethernet Switch
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Some loose contact it seems??? sometime able to connect internet and sometimes not possible?? wat is the reason???
D-Link 1024D performace drops when it gets heated.. Thermal problem.. switch off this equipment for few minutes and try.. keep this equipment in proper ventilation
Jun 01, 2010 | D-Link DES 1024D (DES-1024D) 24x10/100...
I have DES-1005 SWITCH, TO CONNECTED TO (MY WIFE COMPUTER- THE OTHER IS MY COMUTER, WE CAN ONLY OPERATE ONE AT TIME,NOT BOTH.WHAT CAN I DO?
on one computer, go to START>>RUN>>services.msc and press enter, the services window will come up, scroll down & turn OFF DHCP and set to disabled, reboot PC, you should be OK. Also BOTH must be setup on same network name, eg: MSHOME, also both must have an individual name and password. This is under network properties, If you wish to use each others files, you must enable "Sharing" on the hard drive & or folders that you want to share. You can do this by right clicking the drive or folder and choosing "Share" and set that up.
Feb 23, 2010 | D-Link DES 1005 Ethernet Switch
I need a driver for this, lost cd
If you are connecting to the switch using network cable (not usb type), then you don't need software. Just hook up the cable to use it. If your system is not recognizing the switch. then may be you have to install network Lan adapter driver to your network card present in your machine(PC)
I hope this is helpful to you
Thanks
Feb 07, 2010 | D-Link DES 1005 Ethernet Switch
D-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
Dec 13, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
Rating specification of hub
i am giving you some page link where rating is being done on this product
1.http://www.amazon.co.uk/D-Link-1005D-port-100Mb-Switch/dp/B0000687B6
2.http://shopper.cnet.com/switches/d-link-des-1005d/4014-6432_9-32550728.html
check out those link but i was also using that switch but it is not upto the level,i must say it is a entry level mini switch;i don't denied that D-Link is a very good company and i am using there seven of their 48 port switch now;but for this particular product;i don't recommend.
hope it will be helpful to you
Dec 08, 2009 | D-Link DES 1005 Ethernet Switch
Switch D-Link DES3226 Lost Username and Password
Manufacturer can reset that with the mac add. and S/N. if it hasn't been set try leaving username blank and enter admin for the password
Feb 12, 2009 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch Logo
722 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
