Onkyo Integra A-809 input selector switching by itself
Hi, My Onkyo integra A-809's input selector will start randomly switching between input selections. Sometimes it does it very rapidly, and sometimes it works just fine. I'm thinking it must have to do with some interference with the infrared sensor but am not sure. I tried covering the infrared window on the front of the amp but that doesn't work. Any ideas? Should I open up the amp and try and cover or shield the sensor directly? I don't ever use the remote so it wouldn't matter if the sensor was completely blocked.
  • bchall Mar 01, 2008
    Yes, I have had the same problems for several years. I would love to have a fix.
  • Mcraiga Nov 14, 2008
    strBean,
    How did you get Onkyo to respond regarding this bug and the workaround. I tried emailing their support and never got a response. I took the tip from Siliconchip and did some poking around making sure everything was connected inside and that helped - I went weeks without a problem then it started again. I then grabbed the selector knob and worked it back and forth in multiple directions (not rotating it through its selections but really rocking it back and forth) Once I did this a few months ago I haven't had the problem - it started switching once and I did the rocking thing again and no problems. It must have something to do with the inner connections in the switch. Maybe the contacts somehow got corroded or gummed up. I'm reasonably happy with it now as I have a solution that is simple and keeps it working.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
I'm going to assume that your input selector knob just turns and turns, with no stop. Correct? If that the case, you have what's called a Rotary Encoder, which is most likely bad; the very kind of Encoder is used for your volume control. This is not something you can easily fix. It provides inputs to your display microprocessor IC(one of the computers in your unit) It can also be the microprocessor IC, and an input switching control IC. Neither are DIY repairs. If you'd like more information, or would like inquire about repairing your unit, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Dec 16, 2014
    New Friend:
The solution is quite simple - the electrical contact cleaner.
Posted on Aug 16, 2013
Onkyo knows about this bug and has a rather expensive workaround available.
Posted on Nov 13, 2008
  • strBean Nov 14, 2008
    I took the amp to a service shop in Portland, Oregon called
    Innersound. I don't know how they got Onkyo to respond and I'm not
    sure what they did to fix the problem. They said they were talking to
    Onkyo. They charged me $150. It works now - I can occasionally hear
    the original thing going nuts in there, but it doesn't affect the
    source selection. Go figure. Sorry, not a very technical reply. :~)
  • 52 Answers
This is not an IR problem. Could be just loose connectors and dry joints. You'll need to open the unit and visual inspection of the PCB and connector for abnormality.
Good luck.
Posted on Apr 29, 2008
  • Rodrigo Bernabe
    Rodrigo Bernabe Nov 23, 2008
    Hello Mcraiga,
    If all connector had been check inside for lose connection, could be
    a dry solder joint in any of the connectors too...creating intermittent
    contact rendering the input selector to play up. Another thing is the input selector
    of your unit. Aside from the remote, is there any rotary selector at the front panel,
    sort of an encoder rotary...if there is, it might needs servicing...grease inside might
    gummed up.
    Good Luck.
My 92 Acura Integra is not starting could it be my transmission fluid level
Search Results
    "No start" Due to Failed Fuel Pump Relay : Acura Integra ...
    repairpal.com > Problems > Acura > Integra
    where is the fuel system relay located at?I have replaced the distributer 2 times and also the... 1992 Acura Integra. fuel pump???? The car does not start unless I ...
    92 Integra wont start! Very weirdo problemo... - Honda-Tech
    honda-tech.com/acura-integra.../92-integra-wont-start-very-weirdo-probl...
    Jun 13, 2012 - Re: 92 Integra wont start! Very weirdo problemo ..... 91 Integra LS Defroster/Water Leaking, Bigmo5328, Acura Integra, 8, 01-30-2014 12:14 PM.
    92 DA9 WILL NOT START!!! - Team Integra Forums - Team Integra
    www.team-integra.net > ... > Generation Specific > Generation Two
    Apr 5, 2010 - 11 posts - ‎9 authors
    I just bought a 92 integra with the B18A1. The guy I ... Team-Integra.net is the premierAcura Integra Forum on the internet. ... But it still won't start and I don't know what is up. .... Engine will not rotate when attempting to start 98 gsr cranks but won't start. - Team Integra Forums ...
    Feb 9, 2012
    1992 Acura Integra NO SPARK! - Team Integra Forums ...
    Feb 5, 2012
    92 integra wont start after driving - Team Integra ...
    Oct 17, 2010
    Car wont start! has fuel but lil spark..? - Team Integra ...
    Dec 1, 2008
    More results from www.team-integra.net
    My '92 Integra cranks but does not s
Jan 21, 2016 | Acura Cars & Trucks
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Onkyo Amplifiers & Preamps
Hi ,try cleaning your volume control ,here is a video so you can DIY or contact your local service. :)
Dec 17, 2013 | Onkyo Audio Players & Recorders
Does the onkyo A8170 come with a remote
Hi ,it looks like your AMP dose not come with remote control. :)
Dec 09, 2013 | Onkyo Integra A - 8170
The source selector of my onkyo A 807 runs away
HI try this video it worked for me. :)
http://www.youtube.com/watch?v=0Xfm-9jCmjE
Apr 09, 2013 | Onkyo Integra Intergrated Stereo Amplifier...
92 Honda Integra S4 flashing won't start when flashing
change the shift solenoid and it will help ,if this doesn't then change the main relay.
Nov 10, 2009 | 1992 Honda Prelude
Connecting Airport Express to my Onkyo Receiver
Plug it into the cd input, with the two rca cables. We've had this set up for years. No longer use a cd player at all.
Mar 24, 2009 | Onkyo TX-SR803 Receiver
Transmission Problem???????
check the linkage for the selector and see if anything is binding.
Jul 18, 2008 | 1992 Acura Integra Hatchback
Integra DPS 8.5
The Integra DPC-8.5 changer (as opposed to the DPS-8.3 single-play unit -- not sure which you have, as you mention DPS-8.5, a non-existent model) and most of the integra line of players, will sometimes be thrown into brainlock by out-of-step shutoffs. They will usually respond to the Integra/Onkyo instruction manual's directions to turn it off (you're already done that), then unplug the power cord from the back of the machine, wait a few seconds (make it 30 to be safe), then plug it back in and turn it on via the standby switch. The screen should display its welcome message, cycle through startup, and being working again. It is very much like rebooting a PC. In fact there is little difference.
If this doesn't work then something has gone wrong inside and probably has nothing to do with your shutdown method on the way out the door. These things do happen. Hopefully by now you've already figured this out. If not, give it a try. It usually works.
Jul 04, 2008 | Integra DPS-8.3 DVD Player
Onkyo integra a-809 amplifier
Use Deoxit on the switch. It is a contact cleaner available at Radio Shack and Fry's. Exercise the knob well. It worked for me on my newly acquired Onkyo A809.
Jan 13, 2008 | Onkyo TX-SR803 Receiver
3,273 people viewed this question
 Grubhead
Grubhead
