Question about All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater
Heater shuts off when button is released. Is it the thermocouple?
    Problem Solver:
  • 10 Answers
Yes or thermopile
Posted on Dec 11, 2009
Change thermocoupler on all pro 50000-85000 btu heater
If you have replaced the thermocoupler and it still wont stay lit then replace the gas valve.
Nov 18, 2014 | All-Pro Heating & Cooling
Williams heater model 3509612
Hold the button for 30 seconds, then release. If it goes out right away, you have a bad thermocouple. If the unit does not sense that the pilot light is lit, all of the gas is shut off, including the pilot light.
Dec 19, 2012 | Williams Heating & Cooling
Rinnai gas heater not staying ignited
Blocked pilot flame too small or thermocouple needs replacing
May 27, 2012 | Heating & Cooling
My all-pro propane heater will not stay lit for over thirty seconds after I release the red fuel start button,before the flame goes out it makes an air hissing noise right before it shuts off.Heater will...
This sounds like a problem with your thermocouple.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
If this does not solve the problem you may need a new thermocouple and you can find that at www.desaparts.com
Thanks
Jan 04, 2011 | All-Pro Propane Garage Shop Heaters - All...
Water heater pilot
This is more than likely the thermocoupler. The thermo Coupler is a solid cylinder shape with a point on one end and a thick aluminum wire on the other the tip is situated so that it is in the pilot flame. When it reaches a certain temperature from the pilot it sends a signal for the gas valve to stay open and keep the pilot light. If it does not send the signal the valve closes and shuts the gas off for safety. Solution first make sure you hold button long enough to heat Thermocoupler (about 30 sec) if pilot still goes out then replace Thermocoupler. Can purchase at most hardware stores and all plumbing shops.
If this has been helpful please select a rating. Good Luck and have a Grt Weekend.
Apr 01, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot will not stay lit and heater will not light
thermocouple probablly bad, is the flame covering the thermocouple.
the flame has to hit top portion of thermocouple to work correctlly.
Feb 14, 2010 | Endless Summer (GA200209) Stainless Steel...
Heater will not stay lit after releasing button
Make sure your thermocouple tip is in the pilot flame and the other end is snuggly screwed into the control. Clean the pilot if not heating thermocouple. If pilot is heating tip thermocouple and it still goes out after holding the button down for 2 minutes, then your thermocouple is likely bad.
Jan 22, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Torpedo heater lights and runs with control kknob pressed in but shuts down when control knob is released.
Change the thermocouple. The thermocouple scenes the heat from the pilot lit and signals the main gas valve to remain in the ready condition. The main valve will not receive the signal if the thermocouple is bad and will revert to the safety shut down when the control knob is released.
Nov 20, 2008 | Dayton Heating & Cooling
Natural gas patio heater
MAY I KNOW THE EXACT MODEL # OF YOUR UNIT.
Sep 27, 2008 | Heating & Cooling
All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Logo
236 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
