Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have a GE profile stainless steel range. the f7 button lights up and beeps all the time - very annoying. is there any way to turn this noise off. i am assuming my oven is no longer working. two questions: 1) is there any way to stop the f7 beeping noise? 2) i cannot afford a new oven now and i can get by without the oven but the noise is driving me crazy. lrt me add.......i am a female living alone an i can use a hammer and a screwdriver but that is pretty much my capability.
  • micki kristina alston Dec 11, 2009
    hello, it is night time here now. i will try to pull the range out from the wall in the morning and look for the ribbon cable. i will respond to you on tomorrow. thank you for your solutions.
    micki kristina
    mickime@msn.com
  • 3,741 Answers
Intermittent F7 problems are usually caused by poor connections. pull the ribbon connector off the control board and clean the copper connectors using a pink pencil eraser. but if this solution does not helps then its the f7 error due two things out of this two any of the one is faulty so the error comes up and beeps in the unit there is a control touch pad board and ERC board.to check out which one is faulty out of that try this To identify the problem on this one,I cut power to the range and disconnect the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then re-apply power and let it sit that way for 24 hours. If after 24 hours no error code comes up ,then the touch pad is the problem. If, on the other hand, the F7 error code comes back, then the (ERC) is the culprit. to get the required part which is faulty , that you can get it from www.repairclinic.com its worth getting it repaired if you are in two minds.its not very tough thing to do manually but yes bit technical knowledge is advisable.so if you think its bit out of your reach a local appliance repair technician familiar with this brand /model is advisable. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 11, 2009
    President:
  • 1,015 Answers
The F7 error code can mean a stuck control pad button or shorted control pad. You could try unplugging the range from the electrical outlet for 20 minutes and see if the code clears. Otherwise you might need to replace the control panel. In order to stop the beeping noise you will need to remove the back panel of the range(unplugged of course) to get to the control panel. Then you will need to disconnect the ribbon cable that goes from the control panel to the board. you should be able to pull the connector out with a pair of pliers. This should stop the beeping noise. Let me know if you have any other questions.
Stove is beeping and displaying f7
Hi
Thanks for using FixYa. Error F7 on your GE means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 29, 2010 | GE Profile 30" Self-Cleaning Freestanding...
Keypad is flashing and after a minute it beeps the flashes f7
F7 Stuck Button
1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
FIX at that site below. http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
Mar 02, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The f7 number keeps beeping on my GE profile range. i am assuming the oven is no longer working as nothing happens when i push the bake button. the most annoying problem is that f7 beeps all the time; it...
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
you have a stuck button on the key pad you will need a new control board to fix this.
goto http://lartoday.com/order_parts.htm , enter your full model number and search for control
levi
Lebarchrigen Appliance Repair
Mt. Holly, NJ 08060
www.lartoday.com
Dec 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Beeping & flashing F7
It means one of the keys is stuck or shorted. Shorted Clear/Off Key
Control or connector
May 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Error code F7 and controls will not work
I think it have  F7 error not just F...
F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
May 02, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Panel of GE profile gas range says 'LOC ON', how do I remove or reset?
This is the controlled lock out mechanism so that your children cannot play wilth the controls. Press "0" and "9" at the same time and hold them until it says "LOC OFF."
Mar 21, 2009 | GE Profile 30" Slide-In Gas Range -...
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
