Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Furnace does not work when windy outside. Has an electric ignite, it either won't kick on at all, or it just blows cold air. The slightest breeze will cause it to not work. When there is no wind it works great. Right now I can see flame, and it is running but only cold air is coming out. What could be wrong?
  • Coleman Master
  • 43,501 Answers
The problem is withthe venting. Your vent pipe goes out of the house in such a way as to catch the air when it is windy and cause the pressure switch to cut out. The flame may only run for a short time, then shut down and then restart. The heat exchanger never gets hot enough to give you warm air.
Check where the vent pipes exit the house. Try adding on an elbow and turning it so that the wind cannot blow back the pipe. Turning it down towards the ground often is good. Make sure that the exhaust cannot recirculate back to the intake pipe also.
Also check that there is no water build up hanging in a pool where the vent pipe may have sagged a bit. this will make the pressure switch much more sensitive.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 11, 2009
Combustion switch error on windy days
check gas pressure and flame sensor
Jan 06, 2018 | Coleman Heating & Cooling
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Our goodman furnace igniter trys to kick in, but blows cold air. Gas company came checked furnace and told me goodman igniters tend to have this problem of them working fine and then blow cold air at...
it sound slike the presure switch is not working , if it is not lighting try jumping it out it may work some times you can fool it in to working
Feb 21, 2011 | Goodman Heating & Cooling
The ignition kicks on and gives a flame but goes out after 30-45 seconds then starts up all over again. What is going on with it. Its a power vent. It is quite windy outside due to a blizzard going on....
The flame sensor is dirty or bad...it is not telling the control that the flame is lit...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 02, 2011 | Heating & Cooling
Heating unit is blowing cold air...
HEY< this sounds like an electric furnace and some heating elements are not working! WHY! Just call 918-6878813 and see if KOOL BREEZES cAN HELP!
Dec 13, 2009 | Intertherm P3RA-048K Air Conditioner
Furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
RHEEM HIGH EFFICIENT FURNACE-BACKDRAFT SHUTTING IT DOWN
It's the pressure switch on the unit. Make sure that the pressure switch doesn't have debris in it that keeps it from operating smoothly. Take the tubing off from the inducer side and breath in and blow out lightly while listening for a clicking noise. If that doesn't work then I would recommend replacing it. That should solve the issue.
Feb 20, 2009 | Coleman Propane Forced Air Heater...
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Blows cold air
Sounds like you have a problem upon start up of heat. Your safteys maybe shutting you down, and restting voltage to your curcuit board allows you to have another heating cycle. Honestly you may due justice calling a tech.
Dec 19, 2007 | Heating & Cooling
Heating & Cooling Logo
1,497 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
